Radial Slicks Air Pressure #2791317
07/01/20 12:40 AM
07/01/20 12:40 AM
Cleveland Ohio
10secGTX Offline OP
10secGTX  Offline OP
Cleveland Ohio
In my quest to get into the 1.39's 60' or Better ... What tire pressure are you using with the Radial Slick I have Mickey Thompson Pro Bracket Radial Tire. I have tried 18 lbs but I kinda heavy so just getting an Idea what works for others.
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791329
07/01/20 01:52 AM
07/01/20 01:52 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I run Hoosier 9X30 radials on my Valiant. It likes 25. I tried 24 down at Coles County and it spun. My car is fairly light and no horsepower though.
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791331
07/01/20 02:03 AM
07/01/20 02:03 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
with the MT 275 or PBR 28x10.5 I would always run 18 - 18 1/4 psi that was best . I used a 8"rim with the 275s and now 10"with the PBR .
I now run the 29.5x10.5 PBR it likes 19 1/4 psi .
I have also tried Hoosier 29.5 x 10.5 radial , it went to nearly 23psi but just didn't seem to like my car . Has erratic traction .
With the 28s I was foot braking now I use a transbrake and leave @ 4500 . I have a 4.1 gear .
Best sixty is 1.42
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80
Power by Tex's Automotive
Re: Radial Slicks Air Pressure [Re: tex013] #2791356
07/01/20 08:03 AM
07/01/20 08:03 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Hoosier 9 x 30 radial - 21 - 22 lbs works best for me any higher the pattern on the slicks shows the edges are not in contact with the track - any lower the sixty starts to fall off - a good sixty for me is 1.40. with radials its all in the shocks - double adjustable all the way around helped immensely.
Re: Radial Slicks Air Pressure [Re: DoubleD] #2791372
07/01/20 08:42 AM
07/01/20 08:42 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
You say heavy. How heavy?
My car had weight in it for NSS racing this weekend. I had 170lbs in mine. That puts me at 3670. I run 18.5lbs in my 29.5x10 pro bracket radials. I was 1.31-1.32 in the 60 across 4 days.
Our wagon weighs 3800 and we run 22lbs in the 30x9 radials on it. It goes 1.40 in the 60.
Re: Radial Slicks Air Pressure [Re: 66coronet] #2791387
07/01/20 09:44 AM
07/01/20 09:44 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Brother, that wagon is totally badass. Thanks for the picture up
Rich H.
1969 Plymouth GTX
451ci B engine
11.02 at 123mph
NA, 93 octane E10 fuel, DOT tires, mufflers, no trailer
Direct Connection Tech Alumni '05 to '13
Learning without end, your influences, influencing others (all too often unknowingly until years after the fact) and the people you meet are the best part.
Re: Radial Slicks Air Pressure [Re: ZIPPY] #2791396
07/01/20 10:10 AM
07/01/20 10:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
We need some "LIKE" buttons here! up up up
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
HEMICUDA1 says I'm a leader
Re: Radial Slicks Air Pressure [Re: hemi-itis] #2791415
07/01/20 10:57 AM
07/01/20 10:57 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
275 ET Street Pro Radials we run 18 psi.
Best of 1.37 60 ft.
'63 Dodge 330
11.19 @ 121 mph
10.40 @ 130mph with a 200 shot of nitrous. 6.48 @ 105mph in the 1/8th. 1.37 60 ft.
Re: Radial Slicks Air Pressure [Re: GY3] #2791478
07/01/20 12:23 PM
07/01/20 12:23 PM
Locomotion Offline
Locomotion  Offline
The wagon has been around for a while. I remember racing against it in IHRA Stock when it had a legal small block crate motor. The Ross family out of Ohio and Herb McCandless Jr. owned it over the years.
I've run 21-22 lbs in my Hoosier 9" radials on 10" rims. Using a wider rim allows for more pressure while maintaining a flatter footprint. But, naturally, each car has it's own preference.
Re: Radial Slicks Air Pressure [Re: Locomotion] #2791488
07/01/20 12:54 PM
07/01/20 12:54 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
McCandless sold it to Noel Davis and I bought it from him. I think we have had it 7 years. It was still a legal crate car when I bought it. It has a big block in it now and runs Nostalgia Super Stock.
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791517
07/01/20 02:00 PM
07/01/20 02:00 PM
A garage in England
Tig Offline
Tig  Offline
A garage in England
18psi here with pro Drag Radials, dead hooking but looks like they could go a little higher shruggy. 3925lb with driver mid 9's, 1.38 60 with the backs. up
'74 Challenger..9.46 and 145.9 so far, easy pass. 4000lb!!!# N/A, 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 4:10's and 10.5s. Marsh Performance pump gas 655ci.
RHD '68 Barracuda Fastback 323ci street/strip. Best ET 14.18 @ 96.05 Best Mph 98.5
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791544
07/01/20 02:53 PM
07/01/20 02:53 PM
I learn a long time ago that there are many different tire pressure gauges that are off, don't read the same as other gauges read differently, by as much as 3.0 lbs. between three gauges made by the same good brand gauge on the same tire at the same time puke whiney
My message is use only your gauge (and never loaned it out tsk) and test the pressure at the track in 1.0 lb. increments to get the best 60 ft. and reaction times. Once you get close then try using 1/4 lb. changes up scope
I haven't ran radials in a long time so what I use to used is probably not useful now shruggy I ran M/T ET Street 315x60x15 Radials, they liked 18.0 lbs. on my gauge up
My old pump gas Duster weighed 3450 Lbs. with me in it and ran mid to high 1.40 60 ft. with a lot of .010 and quicker lights, occasionally going red with .49 something red lights whiney
Test, test and test some more until your happy up
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791629
07/01/20 07:12 PM
07/01/20 07:12 PM
portland, ct
Since1822 Offline
Since1822  Offline
portland, ct
What size tire and rim are you running? 28x9 PBR?
Re: Radial Slicks Air Pressure [Re: 10secGTX] #2791938
07/02/20 02:35 PM
07/02/20 02:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How are the tires lasting as far as you can tell?
Re: Radial Slicks Air Pressure [Re: 66coronet] #2792724
07/04/20 06:00 PM
07/04/20 06:00 PM
McCandlessboy Offline
I loved this wagon, sadly, didn't have time to continue running it. Used to be lettered "bocephus"
