U joint difference... 8 3/4 ...?? #2791208
06/30/20 08:55 PM
06/30/20 08:55 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
trying to help out a guy ..., what’s the width specs ? Thx
Re: U joint difference... 8 3/4 ...?? [Re: dOc !] #2791221
06/30/20 09:08 PM
06/30/20 09:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
which joint? 7260 or 7290? or is that what you are asking?
7260 U-joint dimensions: 1.078" cap diameter x 3.250" overall width
7290 U-joint dimensions: 1.125" cap diameter with grooves x 3.625" overall width
Re: U joint difference... 8 3/4 ...?? [Re: Sniper] #2791225
06/30/20 09:16 PM
06/30/20 09:16 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Thx S ... I was not aware of the cap dia diff ....
Do you have info on the U joint that mixes the two on one piece ?
Re: U joint difference... 8 3/4 ...?? [Re: dOc !] #2791244
06/30/20 09:45 PM
06/30/20 09:45 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Spicer 25-3244X
neapco 2-0527
Re: U joint difference... 8 3/4 ...?? [Re: Sniper] #2791254
06/30/20 10:11 PM
06/30/20 10:11 PM
BDW Offline
BDW  Offline
Re: U joint difference... 8 3/4 ...?? [Re: BDW] #2791266
06/30/20 10:35 PM
06/30/20 10:35 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Thx B ... Kiljoy will appreciate that !
Re: U joint difference... 8 3/4 ...?? [Re: dOc !] #2791267
06/30/20 10:36 PM
06/30/20 10:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The 1330 joint was used also. Make sure you confirm what you have, and what you need
Re: U joint difference... 8 3/4 ...?? [Re: BDW] #2791268
06/30/20 10:36 PM
06/30/20 10:36 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
It's me he's helping. I have a 489 case. 3.91 s.g. I have the 7260 U-joint. I want to swap a center section with a 741(or 2) case. 2.76 gears. For highway travel.( I haven't changed a u-joint in 30 years or so.)
I have been reading the rear axle tech....
Re: U joint difference... 8 3/4 ...?? [Re: Kilroy was here] #2791270
06/30/20 10:41 PM
06/30/20 10:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Odds are pretty good that if it's a 741 case with those gears it's a 7260 joint, but never say never.
Re: U joint difference... 8 3/4 ...?? [Re: Sniper] #2791484
07/01/20 12:40 PM
07/01/20 12:40 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
They also make adapter u-joints that are 7260 on one cross and 7290 on the other.
Re: U joint difference... 8 3/4 ...?? [Re: slantzilla] #2791952
07/02/20 03:51 PM
07/02/20 03:51 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
just bought one MOOG 347
Re: U joint difference... 8 3/4 ...?? [Re: B1MAXX] #2792356
07/03/20 02:45 PM
07/03/20 02:45 PM
moparx Offline
moparx  Offline
i have a 741 case that has a 7290 joint yoke. [pinion gear missing several teeth. biggrin]
does anyone make a solid joint that is 7290 to a 1350 ?
beer
