Mopar Transmission For Sale - 3rd Quarter #2791112
06/30/20 06:37 PM
06/30/20 06:37 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
1968 Hemi Automatic 2801544 [Re: moparts] #2791165
06/30/20 07:26 PM
06/30/20 07:26 PM
blewbyu Offline
blewbyu  Offline
I have a 1968 Hemi automatic tranny complete with all original Hemi internals with 4 gear planetary. part number 2801544 date code Dec 17th 1967. It is apart for inspection.
$2000.00 plus shipping
68 hemi auto 1.JPG (378 downloads)
68 hemi auto 3.JPG (378 downloads)
68 hemi auto 2.JPG (377 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2791203
06/30/20 08:50 PM
06/30/20 08:50 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts
specialists.
NEW! A and B-body 30 spline main/output shafts, for all 1966-Up 4-speeds:
http://www.brewersperformance.com/proddetail.php?prod=MS-909
http://www.brewersperformance.com/proddetail.php?prod=MS-910
NEW! Speedometer pinion gears for 1966 & later A833 904 and 727 transmissions using long stem style gears, available in 32 33 34 35 36 37 38 39 40 41 42 43 44 and 45 tooth $44.95 each.
http://www.brewersperformance.com/products.php?cat=277
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars $200
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $249.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $349.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 each
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 each
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $64.95
Clutch pedal over center springs $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 each
Shifter linkage rod sets for A B & E body cars $129.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $54.95-$59.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 64-67 and 68-9 4-speeds $11.95 each
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $9.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $109.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $249.95, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $99.95, wiring harnesses from $34.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1299.95
Polyurethane transmission mounts from $69.95
Speedometer cables from $39.95, speedometer pinion gears from $24.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce, McLeod and Ram clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2791550
07/01/20 03:02 PM
07/01/20 03:02 PM
New York
Mopucky Offline
Mopucky  Offline
New York
1969 11” 626 bellhousing $450 pm me here. Free delivery to Carlisle
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2791668
07/01/20 09:40 PM
07/01/20 09:40 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791670
07/01/20 09:42 PM
07/01/20 09:42 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
All parts layed out.jpg (306 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791671
07/01/20 09:43 PM
07/01/20 09:43 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
904 Rear Servo Kit.jpg (303 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791672
07/01/20 09:45 PM
07/01/20 09:45 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791673
07/01/20 09:47 PM
07/01/20 09:47 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791676
07/01/20 09:49 PM
07/01/20 09:49 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is zinc coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each, and includes shipping anywhere in the USA.
I also have the struts for a 904 transmission, same price
Email mrrandyj@aol.com
Re: Mopar Transmission For Sale - 3rd Quarter [Re: mrrandyj] #2791682
07/01/20 10:01 PM
07/01/20 10:01 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
SPEEDOMETER BLOCK OFF PLUGS
CNC machined billet aluminum speedometer hole block off plug. These will fit almost every rear wheel drive automatic and manual transmission from 1966 on up. Uses the factory bracket and bolt to secure it to the transmission. Includes a new o-ring. This is a direct bolt in replacement for the factory speedometer adapter, no modifications are necessary. 100% Made in the USA. $30 each plus shipping. If you have any questions or want to place an order email mrrandyj@aol.com
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2792286
07/03/20 11:32 AM
07/03/20 11:32 AM
sw chicago
RAH Offline
RAH  Offline
sw chicago
I have 2 original 1968 mopar transmissions 2801 544J. Co9mplete for sale asking $3000.00 each. I can bring to Carlisle 2020. breakdown below on each transmission bob h 708 687 1187 224 330 9275 my Email rah@wowway.com
hemi trans jpg 1.jpg (284 downloads)
hemi trans jpg 2.jpg (278 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793570
07/06/20 06:20 PM
07/06/20 06:20 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
B&M Shift Improver Kit, P/N 10225 for 1971-77 727 transmissions (Includes 727 & 904 pan gaskets), new, $35 + shipping 23703.
Direct Connection flex plate & torque converter bolt package set for 7/16” Torque Converters, P/N P4120465. Six crank screws not pictured but are included. $20.00 + shipping 23703
jduster340@verizon.net or PM DusterW2
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793599
07/06/20 07:18 PM
07/06/20 07:18 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
HEMI Torqueflite 727 parts –
NOS Mopar #3420097 Torqueflite update kit includes Wide 5 clutch direct drum (3410900) with wide bushing (1971 only), forward clutch piston retainer and matching pump reaction shaft support.
NOS Mopar #2538047 bevelled forward clutch retainer required for proper clearance with wide direct clutch drum.
NOS Mopar #2801053 High Strength input shaft (24 spline)
Relined Wide Hemi kickdown single wrap band (Red)
NOS B&M Hemi kickdown double-wrap band with special anchor, #10256. Band used on B&M Low Drag Clutchflite units referenced in Hot Rod magazine, January 1971.
All for $ 1300 + shipping 23703
PM DusterW2 or jduster340@verizon.net
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793605
07/06/20 07:24 PM
07/06/20 07:24 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
A833 OD Aluminum A/F-body main case and tail housing, including front bearing retainer, reverse idler gear, shaft and lever. Also, included a NOS A-body OD mainshaft with 26 spline output. Good countershaft bores. $350 + shipping 23703. Also have used OD cluster gear and mainshaft gears available for additional charge.
NOS Mopar Performance synchronizer stop rings (wide slot) (4), new in package. Part number, P4529834. $50 + shipping 23703
NOS A833 steel shifting forks, 1-2, P/N 4130068 & 3-4, P/N 3410038. $200 + shipping 23703
A833 Ball/Detent side cover, 1-2 & 3-4 gear shift levers, detent sleeve, spring, pin and two balls. VGC, $150 + shipping 23703
20190726_152149 jpeg.jpg (155 downloads)
20190726_152247 jpeg.jpg (155 downloads)
20190726_152518 jpeg.jpg (155 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793608
07/06/20 07:31 PM
07/06/20 07:31 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
A833 A-body cast iron main case & tail housing , GC, $250 + shipping 23703
NOS A833 A-body mainshaft with 30 spline output (Non-OD), $250.00 + shipping 23703
64-65 A833 4 speed tail housing, mainshaft, bearing and yoke for A-body. Also, have driveshaft. Mainshaft tip needs reconditioning. $135. + shipping 23703
NOS Mr Gasket grade 8 flywheel bolts for 8 bolt flywheel, Part Number 913. $25.00 + shipping 23703
IMG_0284 modified.gif (156 downloads)
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793614
07/06/20 07:44 PM
07/06/20 07:44 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
A833 23 spline mainshaft gears, clutch hubs, sliders, input shaft and cluster gear. 2.66 1st gear set. Cluster 31-27-23-17R-17; Input 24T, 1st 35T, 2nd 34T, 3rd 29T. Gear clutching teeth are in good condition along with overall gear tooth surfaces. ** Input shaft tip has been shortened. $300. + shipping 23703
A833 23 spline mainshaft gears, clutch hubs, sliders, input shaft and cluster gear. 3.09 1st gear set (Overdrive). Cluster 33-37-27-17R-17; Input 22T; 1st 35T, 2nd 30T, OD 18T. Gear clutching teeth are in fair condition along with overall gear tooth surfaces. $200. + shipping 23703
Mopar 3 speed and 4 speed shifter balls:
Black, P/N 3467683, 3/8-16 LH threads. GC $25 + shipping 23703
White, 3/8-16 RH threads. FC, $20 + shipping 23703
TCS Products 904 7075-T6 Aluminum billet direct drum with 28% larger piston. Has replaceable bronze bushing. New in box with Teflon sealing rings. $500 + shipping 23703
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793623
07/06/20 07:59 PM
07/06/20 07:59 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Superior transmission parts, 727-518 reverse servo, Part #K029, new in box, $30. + shipping 23703
Turbo Action machined pressure plate and snap ring for 727 direct clutch drum, P/N 17299, new $60.00 + shipping 23703.
Mopar Performance shift improver kit for 727, P/N P4349469, new $35 + shipping 23703.
1985 Chrysler 5th Ave transmission cross member with Energy Suspension Poly trans mount, $40. + shipping 23703.
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793630
07/06/20 08:06 PM
07/06/20 08:06 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
NOS 727 direct and forward clutch outer pressure plate, P/N 2124825, sell $20 + shipping 23703.
NOS 727 forward clutch inner pressure plate, P/N 2466803, sell $20 + shipping 23703
NOS 727 forward clutch piston, P/N 3743624, $35 + shipping 23703.
NOS 727 direct clutch friction discs (4), P/N 2124827, $30 + shipping 23703
Re: Mopar Transmission For Sale - 3rd Quarter [Re: moparts] #2793644
07/06/20 08:24 PM
07/06/20 08:24 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
A518 OEM ribbed transmission pan, VGC, $40. + shipping 23703.
Hurst Pit Pack shifter linkage steel bushings and clips, P/N 3327302, new, $12.00 + shipping 23703
