70 CUDA.. DOME LIGHT ON ALL THE TIME #2789329
06/26/20 04:35 AM
06/26/20 04:35 AM
Sweden
71redcuda Offline OP
Sweden
Hello all.
The domelight in a 70 Cuda is on all the time,
it does not matter if both doors are closed or open.
What could the problem be??
Any help would be appreciated!
Nicklas
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 71redcuda] #2789332
06/26/20 05:03 AM
06/26/20 05:03 AM
Caracas, Venezuela, SouthAmeri...
NachoRT74 Offline
NachoRT74  Offline
A tipical fail for this is the use of wrong bulb. Some ppl uses to look inside the socket and note two contacts and run to buy a 2 contact 2 filament bulbs ( I.E. #1157 ) where the correct bulb is 2 contacts 1 filament ( #1004 )
Reason why using the incorrect bulb will keep light on:
Bulbs like 1157 gets the base used to feed the common ground to filaments, where every contact is just positive for each filament.
1004 bulb gets the base isolated from filament and each contact is used for positive and negative ( ground ) for the only one filament inside.
Since dome light is switched by ground getting constant positive, using a 1157 bulb or similar with dual filament will get one of the contacts constantly feeded by the constant positive source at dome light socket, and will get constant negative ground by the socket, because filaments are not isolated from base. Dome light socket is of course attached to body, so is by default chassis grounded ( hence the reason to use an specific bulb )
The next reason could be some of the door jam switches network damaged ( switch, wires grounding, dome light wheel on cluster damaged )
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: NachoRT74] #2789334
06/26/20 05:25 AM
06/26/20 05:25 AM
Sweden
Sweden
Yes! You might be right!
I tested a 1157 bulb and it was light on all yhe time..
i realized it should be a smaller 1004 light so hopefully it will work better.
Thanks for the reply!
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 71redcuda] #2789433
06/26/20 12:20 PM
06/26/20 12:20 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Also don't overlook the dash light dimmer . . . maybe it got bumped and has turned on the dome light ??? Uhh, easiest to check . . .
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: a12rag] #2790880
06/30/20 03:06 AM
06/30/20 03:06 AM
Sweden
Sweden
Still no luck, i have the correct 1004 lamp installed in the dome light, dimmer switch is rebuilt.. BUT the dome light is still on all the time even the doors are closed..
Any ideas what the problem could be ? The door switches is one thing.. but they are new.. I have only checked driver side and there is a yellow cable and a yellow w blk trace going to the switch..
Not sure how the wire routing is from the lamp and forward..
Any help is appreciated.
Nicklas
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 71redcuda] #2790888
06/30/20 06:47 AM
06/30/20 06:47 AM
NachoRT74 Offline
NachoRT74  Offline
driver side should get a 3 pins wire with couple of yellow wires and one black, which handles the lights on and key in warning buzzer signals.
Passenger side should be 2 prongs switch and handles just both yellow wires.
I can make a diagram later, but something is being grounded around on the yellow wire system.
dimmer light on light switch must not get the max point, because that will activate the dome light. Usually they get a small "click" ( not easy to feel ) when dome light is being activated rotating the knob
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: NachoRT74] #2790895
06/30/20 07:37 AM
06/30/20 07:37 AM
NachoRT74 Offline
NachoRT74  Offline
this is based on 71 B body diagram but should work the same on E body
Mmmm althought 70s got a diff lights on and key in warning buzzer setup using positive signal to be activated ( and a diode to isolate both warning signals preveinting a "fedback" ) what would explain why you got just 2 yellow wires and not the black one!... but for the dome light ground circuit should be mostly the same
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 71redcuda] #2790920
06/30/20 09:22 AM
06/30/20 09:22 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Nicklas
Are you sure the new door switches are pushing in all the way to break the ground? I would put a piece of tape or cardboard on the door to make sure the switch plunger is going in for a test.
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: Cuda340] #2790955
06/30/20 11:29 AM
06/30/20 11:29 AM
NachoRT74 Offline
NachoRT74  Offline
iagree
or pushing the switches by hand
I was thinking on that! when these switches are new I think they "autoset" up by themself once doors are closed. The outer sleeve is inserted/pussed to set when the point contacts inside are closed as soon doors are barelly opened.... OR SOMETHING LIKE THAT. Can't explain it
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: NachoRT74] #2790970
06/30/20 12:33 PM
06/30/20 12:33 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
For what it's worth. I purchased new door switches for my '70 'Cuda restoration. Long story short they were crap and I had the originals replated somewhat and they work fine. The replating could only do one color, at least they are clean. I had to do the same with my 1970 Roadrunner. New ones wouldn't work right. Same deal, lights stayed on.
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 469runner] #2790996
06/30/20 01:37 PM
06/30/20 01:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
Door switch might not be working because of paint or bad ground.
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: second 70] #2791026
06/30/20 02:49 PM
06/30/20 02:49 PM
NachoRT74 Offline
NachoRT74  Offline
if it was lack of ground dome light wouldn't light on
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: NachoRT74] #2791045
06/30/20 03:27 PM
06/30/20 03:27 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Do they cycle on and off when you push the switches in by hand? If so, as suggested they are pushed in too far and do not seat/close properly when door is closed. You should be able to pull the outer sleeve outward to adjust properly.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: second 70] #2791104
06/30/20 06:20 PM
06/30/20 06:20 PM
Sweden
Sweden
Thanks for all replies. Problem solved,it was a bad doorswitch.
Nicklas
Re: 70 CUDA.. DOME LIGHT ON ALL THE TIME [Re: 71redcuda] #2791480
07/01/20 12:28 PM
07/01/20 12:28 PM
moparx Offline
moparx  Offline
glad to hear of a positive solution ! up
beer
