Page 1 of 3 1 2 3
Getting beat down by a lawn mower #2790331
06/28/20 02:32 PM
06/28/20 02:32 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm losing my marbles on this one. I can concoct and build all kinds of crazy stuff but I can't keep a stinkin lawn mower running.
I've got a 5 or 6 year old Husqvarna push mower with a B&S engine (metal carb, not plastic). It has always been a great runner that fires on the first pull 90% of the time. Before this issue I can only remember it taking a third pull on a couple occasions. I've got a somewhat small yard and the mower doesn't get used all that often.
I screwed up and fed it some bad gas. The mower would start and die. i drained the tank and cleaned it out. The screen in there was iffy at best so I punched it out and installed a see through in-line filter. The carb had a little bit of scunge in the bowl so I cleaned it thoroughly, including an inspection of the needle and seat as well as holding a properly sized drill bit with my fingers to clean the jet. I then changed the oil, air filter, and plug. It got a tank of fresh gas, too.
When it all went back together it fired up and ran great for about two minutes. Then, it struggled to stay alive. At full throttle it would slow down to a weak idle before picking back up and revving to about 3/4 speed and repeating the process.
It acts like it's running out of fuel but I can see that it's getting plenty. The heat choke seems to be opening properly.
Spark seems to be a non-issue since there is no missing or smoke from incomplete burn.
What am I overlooking?
- Stu Harmon
Re: Getting beat down by a lawn mower [Re: feets] #2790336
06/28/20 02:42 PM
06/28/20 02:42 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
You are not alone! I bought a new cheapie Troy Bilt walk behind for occasional touch-up mowing around close quarters stuff - I have a Deere X-300 that I bought back in 2013 for the main mowing. The Troy Bilt won't start in the spring no matter what I do - and I run ethanol-free fuel. Last year I took it to a small engine guy & left it with him. He got it running no problem - he said there was junk in the carb. This spring - no start. It has a Briggs one-pull start engine. It's a 20-pull no-start. Here it is 2020 & some things are worse-engineered than things from 60 years ago.
Re: Getting beat down by a lawn mower [Re: Sunroofcuda] #2790342
06/28/20 02:52 PM
06/28/20 02:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Buy some Seafoam and some premium fuel.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Getting beat down by a lawn mower [Re: pittsburghracer] #2790343
06/28/20 02:53 PM
06/28/20 02:53 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
What do you expect Seafoam to do in this application? The system appears to be clean.
- Stu Harmon
Re: Getting beat down by a lawn mower [Re: feets] #2790345
06/28/20 02:54 PM
06/28/20 02:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Float level or still trash in the jet?
Re: Getting beat down by a lawn mower [Re: stumpy] #2790373
06/28/20 03:45 PM
06/28/20 03:45 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have a old craftsman 9hp snow blower with a similar problem, has 9hp kohler motor,.
when i got it there was a big surging problem with it. took off the bowl and cleaned everything up. ran better but still had a surge problem,. bought a new carb for $12. didn't surge but barely ran, acts like it not getting fuel. dropped it off by my brother in law who works on small engines on the side it to look at it. been there for 4 months he hasn't had time to look at it yet.
perception is 90% of reality
Re: Getting beat down by a lawn mower [Re: Mr T2U] #2790375
06/28/20 03:57 PM
06/28/20 03:57 PM
PA
70Duster Offline
70Duster  Offline
PA
I'd temporarily bypass the inline filter you added to see if maybe it's too restrictive. I've seen this issue once before. If that doesn't work I'd opt for a new $12 Chinese ebay carburetor. They work amazingly well and seem to last longer that the originals.
Re: Getting beat down by a lawn mower [Re: stumpy] #2790383
06/28/20 04:10 PM
06/28/20 04:10 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
What I usually find is the jet is clogged with a white looking crap,
I believe it's corrosion caused from ethanol in the gas.
Re: Getting beat down by a lawn mower [Re: 70Duster] #2790384
06/28/20 04:15 PM
06/28/20 04:15 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Sometimes the vent in the gas cap plugs up and it starves for fuel. Take the cap off and see if it runs longer than two minutes.
Re: Getting beat down by a lawn mower [Re: fastmark] #2790393
06/28/20 04:34 PM
06/28/20 04:34 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Check your idle speed and the governor linkage. I have a similar husk that did the same thing.
I found that somehow the linkage got caught, possibly by a branch and tweaked. It was binding and wouldn't regulate smoothly.
Angry white pureblood male
Re: Getting beat down by a lawn mower [Re: ruderunner] #2790396
06/28/20 04:44 PM
06/28/20 04:44 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
What happens if you manually cover the intake to restrict the air flow into the carb?
Vacuum/intake leaks can have goofy symptoms.
Re: Getting beat down by a lawn mower [Re: hooziewhatsit] #2790431
06/28/20 06:04 PM
06/28/20 06:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Did you replace the fuel line? I had that issue this past spring line was plugged.
I've taken to not filling the tank full, just estimating how much gas I need then run it till it's dry, even if I have to tie the safety handle down to do that.
Re: Getting beat down by a lawn mower [Re: Sniper] #2790576
06/29/20 07:31 AM
06/29/20 07:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just tuned up my brother in laws generator. Ordered a new carb from eBay for $40 and put a new plug in it. It would do the same thing as yours until I removed the inline filter. It didn't come with a filter originally but the carb came with one. With that gone it runs great.
68 Barracuda Formula S 340
Re: Getting beat down by a lawn mower [Re: feets] #2790580
06/29/20 07:57 AM
06/29/20 07:57 AM
PA.
"Little"John
"Little"John
PA.
Hmmmmm appears. This crap gas that we now get with alcohol causes corrosion and plugs orfaces. Regular use of Seafoam prevents this. Like others have said also check the fuel cap. My tractor was cutting off while cutting the grass. I replaced the fuel filter and it still did it. Left the cap off and I ran great sitting there. Put the cap on and backed it off a turn or two and it ran well cutting last week. See what happens this week.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Getting beat down by a lawn mower [Re: pittsburghracer] #2790589
06/29/20 09:12 AM
06/29/20 09:12 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm NOT a small engine guy but I'm turning into one just to keep the fleet running. The most common problems I'm finding are carburetor problems caused by debris from tank corrosion or just the affects of today's gasoline. I religiously run a mix of Seafoam, red HEET, and premium gas and even after running a carb dry and draining the tank, I still have carburetor problems. BTW, just because it "looks" fine doesn't mean it is.
Re: Getting beat down by a lawn mower [Re: 6PakBee] #2790593
06/29/20 09:29 AM
06/29/20 09:29 AM
St. Louis, Missouri area
Cometstorm Offline
"Beat It"
Cometstorm  Offline
"Beat It"
After checking all the easy stuff already posted, replace the carb.
Been there, fought the same battles, won with the new carb. up
Re: Getting beat down by a lawn mower [Re: Cometstorm] #2790601
06/29/20 10:12 AM
06/29/20 10:12 AM
PA.
"Little"John
"Little"John
PA.
I’m not crazy old (64) and own two acres in the country since 1985 and have never had to replace the carb on any small engine. That includes mowers, tractors, motorhome generators (3), weedwackers, chain saws, power washers, boat engine, go carts, quads, motor cycles, three race track generators, snow blower, rototiller, etc. take care of the fuel and it will take care of you. Today’s fuel is JUNK. It loves eating rubber and plastic fuel lines too.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Getting beat down by a lawn mower [Re: pittsburghracer] #2790608
06/29/20 10:49 AM
06/29/20 10:49 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Time for EFI and a turbo. up
Kevin
Re: Getting beat down by a lawn mower [Re: pittsburghracer] #2790611
06/29/20 10:56 AM
06/29/20 10:56 AM
IL
furious70 Offline
furious70  Offline
IL
FYI my last push mower, bought several years ago from Sears has a B&S 'never change oil' engine and the cap says it'll take E10-E15, but not E85. So far no issues with the fuel system.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Getting beat down by a lawn mower [Re: furious70] #2790623
06/29/20 11:43 AM
06/29/20 11:43 AM
moparx Offline
moparx  Offline
i NEVER have fuel problems with a lawnmower !
the neighbor kid does a GREAT job on my lawn ! biggrin
beer
Page 1 of 3 1 2 3
