Page 2 of 11 1 2 3 4 10 11
Re: Hilborn EFI 512 Charger [Re: CSK] #2672015
06/30/19 05:37 PM
06/30/19 05:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looking forward to hearing how this all works out.
Do you have a sacrificial hood yet?
Does AMD offer one for that?
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2672020
06/30/19 05:50 PM
06/30/19 05:50 PM
Pattison Texas
CSK Online shake_head OP
CSK  Online Shake_Head OP
Pattison Texas
I might cut the glass cowl hood that is on the car, I have a steel cowl hood that I made & it is a short cowl type, but it is very HEAVY, probably will run without a hood at 1st till I get it all working good then make a decision, a glass flat hood would be my best choice. this is the one I made, it was not tall enough for my air filter so I got the glass one about 4 years ago.
Re: Hilborn EFI 512 Charger [Re: CSK] #2672024
06/30/19 05:57 PM
06/30/19 05:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
What’s the air filter situation with the stacks?
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2672030
06/30/19 06:08 PM
06/30/19 06:08 PM
Pattison Texas
Pattison Texas
Speedway had some on sale they are K&N & I dont like them , but they are not to bad if you use an Outerwear over them to keep the fine dust out,
Re: Hilborn EFI 512 Charger [Re: CSK] #2672034
06/30/19 06:18 PM
06/30/19 06:18 PM
Pattison Texas
Pattison Texas
outerwears
Re: Hilborn EFI 512 Charger [Re: CSK] #2672402
07/01/19 10:17 AM
07/01/19 10:17 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Outerwears aren't much better than the filter itself. The only purpose they serve is a quicker cleaning - take 'em of, shake off the crud, a quick scrub with soap and water and off you go. If you want to trap the microscopic dust you have to use a filter coat spray. And then you have to regularly clean the filters to get that [censored] out of there.
Re: Hilborn EFI 512 Charger [Re: Stanton] #2672533
07/01/19 01:04 PM
07/01/19 01:04 PM
Alberta
440_Offroader Offline
Alberta
I agree. The outerwears keep the big partials off the filter (mud in my case), and is just a secondary filtration. Your filter being your primary, the K&N isn't the best at that for sure. Your set up will be very cool, but a aesthetically pleasing filtration system is going to be tough.
Re: Hilborn EFI 512 Charger [Re: CSK] #2672636
07/01/19 05:13 PM
07/01/19 05:13 PM
Pattison Texas
Pattison Texas
The mock up, this is going to take a lot of finesse just to bolt this up,raised port heads would be much better, but I will figure it out.
Re: Hilborn EFI 512 Charger [Re: CSK] #2672695
07/01/19 07:11 PM
07/01/19 07:11 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Really dig that set up!! Wish I could have EFI frown
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hilborn EFI 512 Charger [Re: hemi-itis] #2672759
07/01/19 09:13 PM
07/01/19 09:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
This would look right at home on your blower up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Hilborn EFI 512 Charger [Re: hemi-itis] #2672760
07/01/19 09:13 PM
07/01/19 09:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think it'd be cool if you just put short stacks on it and left it all under the hood. The wow factor would double when you popped the hood.
Re: Hilborn EFI 512 Charger [Re: Stanton] #2672859
07/02/19 07:22 AM
07/02/19 07:22 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
And so would the inlet air temps.
68 Barracuda Formula S 340
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2672916
07/02/19 09:41 AM
07/02/19 09:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
like almost every other car out there !! Besides, an efi adjusts for all that.
Re: Hilborn EFI 512 Charger [Re: fourgearsavoy] #2672945
07/02/19 10:35 AM
07/02/19 10:35 AM
hemi-itis Offline
hemi-itis  Offline
Gus beer
EFI for my heap would be in the $5k range bawling
Re: Hilborn EFI 512 Charger [Re: Stanton] #2672968
07/02/19 11:09 AM
07/02/19 11:09 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Quote
That it does, but it still reduces air density and therefore power.
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2673993
07/04/19 12:52 PM
07/04/19 12:52 PM
Pattison Texas
Pattison Texas
I had to think this one out, the throttle cable & transmission throttle pressure control cable, air filters, the ram tubes will be silver when done., will paint my brackets black.
Re: Hilborn EFI 512 Charger [Re: CSK] #2674014
07/04/19 01:25 PM
07/04/19 01:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looks awesome!
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2674031
07/04/19 01:53 PM
07/04/19 01:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
The car has a/c, I doubt the small loss of power would be a concern. Personal experience tells me to keep everything under the hood and out of plain sight. Nothing attracts destructive morons than stuff peeking out of the hood. You never know when you're going to have to park it somewhere unattended for a while !!
Re: Hilborn EFI 512 Charger [Re: Stanton] #2674036
07/04/19 02:02 PM
07/04/19 02:02 PM
moparx Offline
moparx  Offline
lookin' good so far ! bow can't wait until it's done and you go down the track and report in !
beer
Re: Hilborn EFI 512 Charger [Re: moparx] #2674050
07/04/19 02:26 PM
07/04/19 02:26 PM
Washington
madscientist Offline
Washington
IDK...I kinda like the gold stacks. Adds a little bling to it.
