Battery testing
#2789170
06/25/20 02:29 PM
06/25/20 02:29 PM
Posts: 12,797 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
I charged up an old (but never used) battery overnight. idiot light charger says it's charged. I put the multimeter on it and got
VDC: 11.43
I clicked it over to what I thought was DC Amps and got 3.5
I tried the tester on a known good battery and got VDC: 12.41 and DC Amps (or whatever that is...saw A figured Amps) of 4.3
Can I tell from these readings if that first battery is going to be OK to use?
thanks!
Trying to enjoy life!
Re: Battery testing
[Re: Jjs72D]
#2789364
06/26/20 09:20 AM
06/26/20 09:20 AM
RapidRobert
On a side note something I saw on youtube (fwiw!) they said new batteries on the store shelf, you want to grab one that has the newest mfr date, that they slowly go bad just from sitting too long
Re: Battery testing
[Re: RapidRobert]
#2789426
06/26/20 11:57 AM
06/26/20 11:57 AM
Posts: 19,310 north of coder
moparx
On a side note something I saw on youtube (fwiw!) they said new batteries on the store shelf, you want to grab one that has the newest mfr date, that they slowly go bad just from sitting too long i have been doing that for many, many years now. sometimes, the fine print on the warrentee states that it starts on the date of manufacture, NOT the date of sale ! my brother found that out the hard way years ago. it took LOTS of complaining to the parts store that sold it to even get a pro-rated refund ! ALWAYS get the newest date possible, and ASK the clerk to make SURE you understand the warrentee !
Re: Battery testing
[Re: calmopar]
#2789491
06/26/20 01:51 PM
06/26/20 01:51 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
I think the challenge now is with "sealed" batteries and trying to desulfate and risking burning off electrolyte, so they probably dont push the battery too much. People are not used to even looking at this now or in some cases, cant even get the caps off. When I was a kid my Dad would use a pretty healthy manual charger and charge them hard, but maintaining electrolyte level, so the plates stay covered. And you can test the specific gravity to see if it is working. I did this with my old restoration battery to keep alive about 11 years. Worked for a long time, but in the end the battery self destructed one day during cranking and exploded. That was a bad day.
Re: Battery testing
[Re: moparx]
#2789657
06/26/20 07:53 PM
06/26/20 07:53 PM
Posts: 4,848 Memphis
HemiRick
Memphis
My local Advance store considers batteries that have sat on the shelf for 18 months "used" and sells them for $42.99, I have bought many of these and most work fine.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Battery testing
[Re: 5thAve]
#2789668
06/26/20 08:34 PM
06/26/20 08:34 PM
RapidRobert
I saw another utube vid (how I have been spending my isolation!) where they charged a bad battery with 4 loads of distilled water (iirc) & it restored it, shouldn't be too hard to find. & noted that the mfr day issue is legitemate
