Re: new Best
[Re: 10secGTX]
#2789360
06/26/20 09:12 AM
06/26/20 09:12 AM
Posts: 12,390 Taxes & Virus's R-US, NY
Dragula
Hi all, It's been a while ...
I finally got a chance to get back to the local Track, with a couple upgrades 1. New Ignition a Daytona Sensors 2. New Gears 4.30 formerly 3.90
results 1st pass Hot as Hell engine was 200 degree's on the tree 10.07 @ 131 1.46 60' 2nd pass engine cooled 9.99 @ 133 1.44 3rd pass temp was down outside and removed the hood added carb spacer 9.84 @ 131 1.41 60' !!!!!!
That's flying for that big tub....Congrats. What's the engine combo? Interesting you're 60ft seems light and so does your mph to go 9.84, so the mid range has to be really pulling...What are you shifting at, are you short shifting it? I can tell you, there is more in that combo...If I had to guess, I would looking to see if its lean on the top end, and adding more timing for the 60ft...Where is the timing mark on the plugs?
Re: new Best
[Re: Dragula]
#2789708
06/26/20 10:42 PM
06/26/20 10:42 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
That's flying for that big tub....Congrats. What's the engine combo? Interesting you're 60ft seems light and so does your mph to go 9.84, so the mid range has to be really pulling...What are you shifting at, are you short shifting it? I can tell you, there is more in that combo...If I had to guess, I would looking to see if its lean on the top end, and adding more timing for the 60ft...Where is the timing mark on the plugs? I have to confess .... if you look at the best pass mph I lifted. Things are happening way faster than when it ran 10.60's obviously, I shift at 6800 and it was pulling BUT it seemed like the shift light was on forever !!! timing is 34 and we didn't pull a plug so yes I hope there is more in it. Andy F where did this engine stop making power ? I have the limiter at 7500. I will have more DATA as soon I can get my act / seat time together The Engine is Andy's former 514 Dyno engine
Re: new Best
[Re: 10secGTX]
#2790674
06/29/20 02:37 PM
06/29/20 02:37 PM
Posts: 2,297 NE Ohio
DoubleD
NE Ohio
- Here is my time slip from the next day out at 42 - you must be lifting before the last MPH cone incrementals are pretty close - you are a little quicker starting at at the 330 - We are pretty close in weight at around 3800 or so - Congrats on the new best - you are in the nines!
