Odyssey battery in original case conversion #2788442
06/23/20 12:28 PM
06/23/20 12:28 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
I know a group 27 battery can have the odyssey pc925 battery swapped inside the case of a group 27. Will the pc925 fit inside a gutted group 24 yellow cap case or is it too small? Has anyone done a group 24 conversion?
inherited a 69 roadrunner from my grand pop.
Re: Odyssey battery in original case conversion [Re: fuelishnsilly] #2788449
06/23/20 12:40 PM
06/23/20 12:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm wondering what's the best method for cutting the case open, and what to do with the acid & internals.
I have a 24 restoration battery here that doesn't hole a charge, but am reluctant to just toss it.
Re: Odyssey battery in original case conversion [Re: topside] #2788500
06/23/20 03:18 PM
06/23/20 03:18 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This is how I did my Group 27. The same battery should fit inside a Group 24 based on the dimensions. https://www.forabodiesonly.com/mopar/threads/battery-gutting.440367/#post-1972606623
PC925
Length inches (mm) 6.64 (168.6)
Width inches (mm) 7.05 (179.0)
Height inches (mm) 5.83 (127.0)
A messy job!!!
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Odyssey battery in original case conversion [Re: RealWing] #2788521
06/23/20 04:34 PM
06/23/20 04:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thanks for the info ! up
