Re: Steel or wood garage? [Re: astjp2] #2789223
06/25/20 06:15 PM
06/25/20 06:15 PM
AndyF Offline
AndyF  Offline
Originally Posted by astjp2
Well I am contemplating a 50x80, going big enough to put everything out of the sun and snow...pole barn was my first choice up until I realized that I have a high water table at 3' below grade, so I will just do a steel building on pilings
50x80 is bit for a wood building, especially if you want clear spans. If you can live with poles in the middle of the building then wood would probably work. My shop is 50x60 and the engineer said I need to go steel in order to have clear span beams that would support a 1 ton bridge crane. Wood wasn't even in the running.
Re: Steel or wood garage? [Re: roadntrack] #2789225
06/25/20 06:19 PM
06/25/20 06:19 PM
AndyF Offline
AndyF  Offline
Originally Posted by roadntrack
Mine will just be a 12x28 Main concern is condensation with steel vs wood
Condensation is not a problem if you insulate the building. If you leave the exterior panels exposed to the inside of the building with zero insulation then you'll have a problem. But that won't be your only problem since your heat bill will also be sky high.
Re: Steel or wood garage? [Re: roadntrack] #2789237
06/25/20 07:19 PM
06/25/20 07:19 PM
Anderson, SC
resqguy Offline
resqguy  Offline
Anderson, SC
Don't mean to hijack, but those that have steel garages that have traditional pitch (6 or 7/12) and decent overhangs, did you choose a specific company or was your contractor able to provide these options. Most steel garages I find have more flat roof pitches and no overhang. I need a building that is HOA friendly, but the manufacturers haven't been helpful.
Re: Steel or wood garage? [Re: resqguy] #2789241
06/25/20 07:40 PM
06/25/20 07:40 PM
AndyF Offline
AndyF  Offline
Overhangs are a good subject. That is one place where steel makes it easy. The steel building company that I worked with just asked me if I wanted overhangs and how big I wanted them. I had a medium overhang in the front so I can unload a truck without getting wet in the rain. At the rear of the building I went with the max allowed overhang to provide a carport/RV parking area. I also asked them to finish the underside of the overhangs with a contrasting color just to make it look nice. They mounted lights on the rear overhang area so I can see what I'm doing in the dark.
Re: Steel or wood garage? [Re: AndyF] #2789246
06/25/20 07:58 PM
06/25/20 07:58 PM
Superfreak
Superfreak
That is a big overhang for a snow load.
Re: Steel or wood garage? [Re: ] #2789261
06/25/20 09:20 PM
06/25/20 09:20 PM
AndyF Offline
AndyF  Offline
I don't think the guy who asked about overhangs cares about snow loads.
Re: Steel or wood garage? [Re: AndyF] #2789262
06/25/20 09:22 PM
06/25/20 09:22 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Originally Posted by AndyF
That look nice. I see that you used a steel interior in your wood building. That is a good idea in a shop since the steel siding will stand up to more abuse than drywall. It is a little harder to install though.
Thanks, The inside walls are 7/16 OSB covered with Steel for fire proofing and as you stated durability. Also ease of clean up...hose and a mop...just gotta get to it. My Plasma table makes a brown mess of everything.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Steel or wood garage? [Re: W.I.N. Racing] #2789267
06/25/20 09:29 PM
06/25/20 09:29 PM
AndyF Offline
AndyF  Offline
Did you insulate under the OSB? If so, that would make for a very nice shop. Insulation, then OSB and then a steel liner on top would be a heck of a combo.
Re: Steel or wood garage? [Re: AndyF] #2789642
06/26/20 07:18 PM
06/26/20 07:18 PM
Byron, NY
Byron, NY
there is 7/16 OSB on the exterior with Tyvec, 6" fiberglass in the walls. a 4 mil vapor barrier and then additional 7/16 OSB. The Steel screwed directly to the OSB. The building is tighter than a Zip Lock bag. I have radiant floor heat that cost less than $100/mo to keep 2000sq at 60deg 24/7. Turning on the lights raised the room temp 3 degs
Again thank you. I am proud of this shed, I designed and built all aspects (except the concrete - I let younger backs do that) from the building lay out, electrical and heating system and the only thing I would change is the concrete contractor... long story - poor workman ship
'60 Willys CJ5
Re: Steel or wood garage? [Re: roadntrack] #2789770
06/27/20 08:36 AM
06/27/20 08:36 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I built a hybrid steel truss garage 30x40 about 10 years ago. Gives you the benefits of both wood and steel buildings Did all the work myself except concrete.
I heat with a wood a stove since I have endless amounts firewood. It does seem strong had a tornado come through the backyard a few years ago and no damage.
https://miracletruss.com/
One nice feature that accidentally happened was I ended up with a loading dock in the back. It is nice to being able to backup and roll large items out my pickup.
Re: Steel or wood garage? [Re: roadntrack] #2792257
07/03/20 10:37 AM
07/03/20 10:37 AM
GMP440 Offline
GMP440  Offline
This video was interesting and the person that did it talks about the cost to complete everything on the metal building.
https://www.youtube.com/watch?v=iwgeRgl8YZI
Re: Steel or wood garage? [Re: GMP440] #2792411
07/03/20 07:01 PM
07/03/20 07:01 PM
AndyF Offline
AndyF  Offline
That is a really bare bones low end building. More of a storage shed than a shop. Better than nothing though, that is for sure.
Re: Steel or wood garage? [Re: AndyF] #2792415
07/03/20 07:17 PM
07/03/20 07:17 PM
GA
roadrunninMark Offline
GA
What metal building companies have you guys used? I’ve seen a few negative reviews on some for leaking, like Eagle. I am looking as well to do a 30 X 40. I do like the overhang for shade, how deep can it be made?
I think I would like to use spray foam insulation, walls and ceiling too.
Re: Steel or wood garage? [Re: roadrunninMark] #2792468
07/03/20 10:28 PM
07/03/20 10:28 PM
AndyF Offline
AndyF  Offline
I used OPC here in Oregon. They aren't going to be much help where you are at but there is probably somebody similar in your area.
https://www.oregonpacificconstruction.com/index.html
Re: Steel or wood garage? [Re: AndyF] #2792493
07/04/20 12:22 AM
07/04/20 12:22 AM
5thAve Offline
5thAve  Offline
A buddy of mine has one of those. I call it the glorified shed.
