1927 Chrysler Model 50
All steel with full fenders and running boards
Top chopped 4”
All new windows - safety glass
Independent front suspension
8-3/4” rear axle with parallel bars and coil overs
Interior completely redone with late model buckets, carpeting, doors and headliner, steering column
Trunk finished off including aluminum fuel cell
Stroked 360 with new Eagle crank and rods, Diamond pistons, Magnum cast iron heads by Modern Cylinder Heads, Comp Hydraulic flat tappet, LD-340 intake and carb, shorty headers, dual exhaust, engine is broken in, car has less than 20 miles on it.
Fresh 518 trans and high stall street converter with lockup.
Aluminum radiator
Fresh Radial T/A tires
Stockton steel wheels
Needs front end alignment, some electrical to be finished for the lights and the running boards installed
I’ll be posting some pics soon
$35,000 or best offer. Negotiable.
Contact me by PM and I will hook you up with the owner.
