Re: Carburetor & Intake Compatibility Question
[Re: elmor353]
#2788231
06/22/20 08:13 PM
06/22/20 08:13 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I used to run a stock 360, 2 bbl intake and carb on a stock 318. Got it to run 14.40 so while it isn't optimal, it also isn't that bad. Since the OP only wants to run this for the summer it should be fine.
[Re: elmor353]
#2788322
06/23/20 01:19 AM
06/23/20 01:19 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
The Edelbrock Performer DOES have the smaller intake ports. I have 3 of them in my shop. Cab, I think you were referring to the early LD4B(small ports) or the LD340(large ports). Your correct, thanks for the help Maybe the DP4B was a 361,383 or 413 426street or a early 440 intake
[Re: elmor353]
#2788696
06/24/20 01:34 AM
06/24/20 01:34 AM
Posts: 4,848 Memphis
HemiRick
Memphis
At full throttle the reversion problem is minimized, and the diff between big and small port is no big deal. The place a small port manifold excels is in throttle response and part throttle power. The small port 4 bbl manifold, makes my current 318 more fun to drive than any other 318 I've ever had. It has immediate throttle response w tons of torque, will spin a tire w ease at much less than full throttle. You can build engines like me your whole life before you find a combo like this. Ever put headers on an old Ford 360-390 ? same kind of deal amazing results for minimal effort.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: scratchnfotraction]
#2789011
06/24/20 10:16 PM
06/24/20 10:16 PM
HemiRick
Memphis
The LD4B is what I have.....why they ever stopped making these I'll never know....best intake for a 318 ever by FAR !
[Re: HemiRick]
#2789094
06/25/20 09:07 AM
06/25/20 09:07 AM
Posts: 15,487 Florida
scratchnfotraction
The LD4B is what I have.....why they ever stopped making these I'll never know....best intake for a 318 ever by FAR ! I have had the LD4B on a 360 engine and a couple 318s with the 360 heads. the small runner/ports keep the velocity up going from small to large port and worked rather well on the street daily driving. I have been dropping 360 heads on 318s since I was 15 and now I am 56 don't care what negatives people SAY it has as it works and makes up for it in the mid to top end RPM range. exactly why Ma Mopar did it in 85 for the 318. and it got a bump in CR to the 9.0 to 1 and used the q-jet/intake. FYI... stock 318 2v = 150 HP @ 4800 rpm stock 360 headed 318 4v "police engine" = 177HP @ 4800 rpm 85-91 now the "police engine" did run a better cam with the 360 heads/q-jet Ma Mopar did a few good things for the teen from 85-91 and sure made plenty of them. I open the bowls up and clean up the runners home porting the heads and install pistons backwards to change piston rod offset and use about 214*/228* dur @ .050 with .485/.500 lift and my little 318s are screamers in daily traffic. run mid 13s 1/4 mile track 4000lb truck. old skool tricks still work for the poor man 318 daily driver.
[Re: Old_Moparz]
#2793529
07/06/20 05:06 PM
07/06/20 05:06 PM
Posts: 3,460 Newburgh, NY
Old_Moparz
Newburgh, NY
I've been making it part of my daily routine to look here on Moparts, Ebay & Craigslist for intakes. I spotted a few that were decent deals, but the shipping is always a killer on the old cast iron & most will require a massive amount of cleaning to get the carbon out from inside. I saw a clean one for $75 that was VERY tempting, but it was a 2-1/2 hour drive one way. I told myself to just wait until the Carlisle show because there's bound to be a bunch of them there & I've carried heavy crap across the fairgrounds all the way up the hill to where my truck is before. This past weekend there was a new ad on eBay for a brand new Edelbrock Performer for $140 & $38 for shipping. I thought about it, passed on it & went to bed. After laying there looking at the ceiling & thinking about how a crusty old intake needs to be cleaned up, I turned my phone back on & went right to eBay & clicked the "BUY IT NOW" button. I have this same intake on my Scamp & did the same 2V to 4V swap ages ago so for roughly $50 to $75 more than what I planned on spending, this will save me a bunch of grief. Thanks for all the ideas that were posted.
[Re: Guitar Jones]
#2794097
07/07/20 10:16 PM
07/07/20 10:16 PM
Posts: 2,275 ILLINOIS
volaredon
ILLINOIS
I used to run a stock 360, 2 bbl intake and carb on a stock 318. Got it to run 14.40 so while it isn't optimal, it also isn't that bad. Since the OP only wants to run this for the summer it should be fine. I did the same on a 318 in a 76 Charger SE.... ran fine on the street, daily driver, work car, etc. never took it to the track but it ran better than with the original 318 intake and carb.
[Re: Sniper]
#2802154
07/28/20 02:38 PM
07/28/20 02:38 PM
Old_Moparz
Newburgh, NY
Just a follow up in case anyone was wondering. New is nice, but it's nicer when it's cheap. I'm into this entire set up so far for about $375 including the intake, the carb, all the linkage pieces, brackets & gaskets to do it. Now I just need to find the time to actually swap it all. I will hold onto the stock, cast iron intake for now since I still have another 318-2V engine kicking around in my Coronet convertible that one day may get redone.
