Original headlights for 70 Cuda #2785680
06/15/20 11:26 AM
06/15/20 11:26 AM
italy
antonellomopar Offline OP
italy
Hello
how can I understand if the original headlights are still mounted on my 70 Cuda? Are there any markings that differentiate the late model General Electric headlights from the original? Have some old headlights in my garage and would like to understand if they are original. Thank you
Re: Original headlights for 70 Cuda [Re: antonellomopar] #2785726
06/15/20 12:45 PM
06/15/20 12:45 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
What I've seen over the years are date stamps on backside of bulbs. Problem is the stamps are often very hard to read.
Ron
Re: Original headlights for 70 Cuda [Re: RJS] #2785736
06/15/20 01:18 PM
06/15/20 01:18 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Those stamps can be washed off with soap and water, so be careful if you need to wash your bulbs.
Re: Original headlights for 70 Cuda [Re: John Brown] #2785793
06/15/20 04:47 PM
06/15/20 04:47 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I would say wide flute GE bulbs were there from new. twocents
Re: Original headlights for 70 Cuda [Re: 5carguy] #2785808
06/15/20 05:31 PM
06/15/20 05:31 PM
italy
italy
Does anybody have a pic? What does wide flute mean?Thank you
Re: Original headlights for 70 Cuda [Re: antonellomopar] #2785835
06/15/20 06:46 PM
06/15/20 06:46 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Flutes are the "ribs" you see on the lens.
The earlier sealed beams on American cars had wider flutes than the later lamps.
Especially so way back in the 1920s-1930s.
I can't recall exactly, but I think in the mid- to late-1970s, the narrow flutes appeared.
Re: Original headlights for 70 Cuda [Re: topside] #2786094
06/16/20 04:53 PM
06/16/20 04:53 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
This is a correct for 70 Cuda wide flute GE bulb
Re: Original headlights for 70 Cuda [Re: 5carguy] #2786096
06/16/20 05:05 PM
06/16/20 05:05 PM
italy
italy
Thank you...really appreciate the pic
Re: Original headlights for 70 Cuda [Re: antonellomopar] #2786162
06/16/20 09:04 PM
06/16/20 09:04 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
probably 6012s
What's the owners manual say?
Then you can look at the pdf and see what was likely.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2618519/Searchpage/2/Main/216740/Words/%2BHeadlight/Search/true/re-70-cuda-headlight-question.html#Post2618519
