Alternator Case Sizes #2785349
06/14/20 11:59 AM
06/14/20 11:59 AM
Usa
A39Coronet Offline OP
Usa
After getting incorrect information directly from Mopar Part Assistance, I figured I'd share that out of the 220, 180, and 160 MDS alternators the 160 is the only small case of the three. Part #04801866AC fit in my ebody without needing to modify anything. This may already be common knowledge but I figured it may be worth repeating.
I'll be hooking this to a pre-70 P3690732 regulator to regulate the 13.5v output.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Alternator Case Sizes [Re: A39Coronet] #2785552
06/14/20 10:30 PM
06/14/20 10:30 PM
IL
furious70 Offline
furious70  Offline
IL
i was surprised the alt fit in my 69 Coronet as well, 2005 300C engine, must have had the 160a as well.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Alternator Case Sizes [Re: A39Coronet] #2785636
06/15/20 10:34 AM
06/15/20 10:34 AM
Usa
Usa
When they switched to the MDS timing cover, the spacing on all the accessories changed. I learned this the hardway as my original alternator didn't line up with my water pump. The unit I'm using is for the later timing cover (totally flat where the WP mounts).
I'd have to check my notes for the year, but as soon as the timing cover became flat, and didn't have the water pump flow provision, the alignment changed. The case size, but pulley spacing, should follow this 160/180/220 size pattern all the same.
Re: Alternator Case Sizes [Re: A39Coronet] #2785644
06/15/20 11:04 AM
06/15/20 11:04 AM
IL
furious70 Offline
furious70  Offline
IL
per my other thread I posted this morning - you're saying MDS vs non-MDS means different timing covers? What about VVT?
70 Sport Fury
68 Charger
69 Coronet
72 RR
