will an 03 timing cover/accessory drive bolt up to an eagle? #2785625
06/15/20 10:19 AM
06/15/20 10:19 AM
IL
furious70 Offline OP
IL
The early truck timing cover/accessory drive with the radiator hose going to the dr's side could help me package the turbo on the pass side - is it interchangeable with both car and truck eagle engines?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: will an 03 timing cover/accessory drive bolt up to an eagle? [Re: furious70] #2785643
06/15/20 11:00 AM
06/15/20 11:00 AM
IL
IL
and/or does that early waterpump interchange with the later cover aside from any belt interference to deal with?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: will an 03 timing cover/accessory drive bolt up to an eagle? [Re: furious70] #2785655
06/15/20 11:29 AM
06/15/20 11:29 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Early waterpump won't work with later timing cover because early pump impeller protrudes beyond the pump gasket face. It relies on the timing cover for clearance.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: will an 03 timing cover/accessory drive bolt up to an eagle? [Re: A39Coronet] #2785663
06/15/20 11:50 AM
06/15/20 11:50 AM
IL
IL
I'm wondering about interference to VVT cam sprocket now with early cover.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: will an 03 timing cover/accessory drive bolt up to an eagle? [Re: furious70] #2785764
06/15/20 03:43 PM
06/15/20 03:43 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
I'm pretty sure the 6.1 and the early non-VVT 5.7 are the same. They are not interchangeable with the Eagle 5.7, 6.4 etc.... the VVT stuff.
