Who to call for solid roller cam
#2783647
06/10/20 12:50 PM
06/10/20 12:50 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am putting a new set of Trick Flow power port 270 heads on my 500 CI RB and need to have someone spec a cam for me. I bought a used one and it doesn't seem to fit. The bearings seem to be to tight. Weird thing is I have had 3 different cams in these exact bearings. I would assume the used one I bought is bent or not the right tolerance to start with. I was going to call Hughes engines. Any other suggestions? Thanks in advance.
67' charger 499 RB
10.57 at 127
Re: Who to call for solid roller cam
[Re: tboomer]
#2783663
06/10/20 01:07 PM
06/10/20 01:07 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Dwayne Porter..He will fix ya up right! What block are you using?
[Re: markz528]
#2783666
06/10/20 01:10 PM
06/10/20 01:10 PM
dragram440
bigfork mn
Stock 1969 440 block. Same block i have been running the last 8 years with this 500" setup.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2783669
06/10/20 01:11 PM
06/10/20 01:11 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I'm sure Dwayne is good but you might want to call Bullet Cams,662-893-5670 or Ultradyne cams at 662-893-8022. They are in the same shop so either one should be able to help you on getting a good cam, they are Mopar specialists also
[Re: dragram440]
#2783671
06/10/20 01:13 PM
06/10/20 01:13 PM
Posts: 4,662 On the parachute mount
n20mstr
I use Scott Brown for any camshaft …..
IF you have cams that spin and one that doesn't? sounds like that cam may be a lil bent???. Usually if the bearings are new, they may be a little tight and need a scraping here and there, BUT that should be with any cam, not just one.
Good luck
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2783732
06/10/20 02:52 PM
06/10/20 02:52 PM
Posts: 10,009 MN
JERICOGTX
MN
With no disrespect to Dwayne, I like my Scott Brown cam. Now all my head work will go to Dwayne...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2783738
06/10/20 02:59 PM
06/10/20 02:59 PM
dragram440
bigfork mn
How do I get a hold of Scott Brown? Not finding anything googling it.
67' charger 499 RB
10.57 at 127
[Re: n20mstr]
#2783802
06/10/20 05:41 PM
06/10/20 05:41 PM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
No question....Dwayne Porter for all and any camshafts!!
[Re: Hemi Allstate]
#2783914
06/10/20 10:11 PM
06/10/20 10:11 PM
Posts: 3,504 DFW
mr_340
DFW
I would call Billy Godbold at Comp Cams. I would bet he has the latest designs.
Floyd Lippencott IV
[Re: mopar dave]
#2783940
06/10/20 11:22 PM
06/10/20 11:22 PM
dragram440
bigfork mn
12.25-1 i might have the heads decked to get the chambers down a little. Trick flow 270 heads
67' charger 499 RB
10.57 at 127
[Re: mr_340]
#2784012
06/11/20 09:40 AM
06/11/20 09:40 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Funny thing about calling cam companies,,,,,called Comp for instance 5 times and got 6 different cams. My next cam would be spec'd by Dwayne! It's all about the combination!!!
[Re: dragram440]
#2784018
06/11/20 09:54 AM
06/11/20 09:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How do I get a hold of Scott Brown? Not finding anything googling it. I ran a Scott Brown cam for a few years.. that cam was just down right WRONG for my set up and he speced it out and I didnt like the 112 center line which he really likes.. if this is a race set up you would be better off with Ultridyne
[Re: hemi-itis]
#2784040
06/11/20 11:06 AM
06/11/20 11:06 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
And why Isky is the best overall in MY world and all I use plus my roller has the most aggressive street-ish lobes while being easy on parts. 14+ years and changed springs twice and rebuilt the roller lifters once so far. Easy mid 9's and 6-teens so far and driven a good amount.......680-.660 276-281 on a 108 lsa w/97 degrees of overlap.....
