1956 CORONET #2776622
05/20/20 10:29 PM
05/20/20 10:29 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Before I travel 200 miles to see the car, Can a RB fit inside? This a coil spring or leaf sprung rear? I'm not looking to make a street car but rather a rat drag car.I know that anything can be fab'd but looking for a simplier ride.Thanks
Re: 1956 CORONET [Re: A/MP] #2776669
05/21/20 09:12 AM
05/21/20 09:12 AM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
I can't help you on the RB, the rear springs are leaf I think.
Re: 1956 CORONET [Re: Old Ray] #2776683
05/21/20 09:57 AM
05/21/20 09:57 AM
moparx Offline
moparx  Offline
rear leaf springs. if it were me doing as you want to do, i would ditch the front suspension and original steering box, then put a straight axle in it's place.
a big block would be easy to install then.
we need to see pics !
beer
Re: 1956 CORONET [Re: moparx] #2776715
05/21/20 11:47 AM
05/21/20 11:47 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Front suspension is coil spring. Very similar to my 51 Plymouth's, can;t help on the B/RB question though.
Re: 1956 CORONET [Re: A/MP] #2776727
05/21/20 12:44 PM
05/21/20 12:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure, depends on your fabrication skills. The rear leaf springs are what's referred to as "splayed", the front mounting points are closer together than the rears.
Re: 1956 CORONET [Re: John_Kunkel] #2776845
05/21/20 08:11 PM
05/21/20 08:11 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
There is enough space under the hood for an RB. You may loose the inner fenders, and probably the fresh air for the heat, neither of which you probably would have left intact anyway.
The front suspension, if its in good shape will support the RB's weight. It is a decent suspension that parts are available for at many auto parts stores and online. Improvements can be had by moving the shock from the upper control arm to a bracket on the frame, kits are available to do this, but its pretty simple. You definitely want a disc brake conversion, several kits are offered. Its cheaper to do a disc brake conversion then it is to rebuild the original brakes, which would be inadequate for a RB powered car.
The rear suspension, if in good condition will support an RB, but I would swap out the usually open rear axle for something a little bigger, with a sure grip, and much more modern,. The original brakes and rear drum setup is poor design, and the axle flanges are keyed to the axles and probably wouldn't hold up to an RB with traction, which the open diff probably couldn't supply anyway.
You want to make sure the car your looking at has a good frame. They tend to rust out in the lower part of the front cross member, and on the frame rails in front of and behind the leaf spring mounting points. If the frame is not rusted beyond repair and is not bent, they are plenty tough enough for an RB.
It will be required for you to post up pictures and keep us informed about your build. Gene
Re: 1956 CORONET [Re: poorboy] #2777028
05/22/20 01:47 PM
05/22/20 01:47 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
They stuffed big old Hemi's in similar cars , should fall into place ( lol)
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1956 CORONET [Re: poorboy] #2777163
05/22/20 07:24 PM
05/22/20 07:24 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Thanks for the info of the K rust issues. That's going to be my main concern when I see it tomorrow.
Re: 1956 CORONET [Re: A/MP] #2777929
05/25/20 08:27 AM
05/25/20 08:27 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I am sure the bb or RB will fit as I had for years a 1956 Plymouth Belvedere . with a stroked 440...I sold it 2 years ago to a guy in Tennessee Have many pics but can't send them in my new PC without my grand son to show me how..I at first had the original K frame ,then I installed complete K frame from a Chrysler 5th ave....The P/S was the only hang up....the exhaust had to be worked a lot..Many pics around Moparts including Owners pics I think page 3..White with gold trim..car ran 11.38 with no good traction..1.77 60 foot Good luck Larry
Re: 1956 CORONET [Re: dynamite] #2778034
05/25/20 12:51 PM
05/25/20 12:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Dakota front clip swap is popular in the '55-'56.
https://board.moparts.org/ubbthread...-dodge-modern-front-end-swap-advice.html
Re: 1956 CORONET [Re: John_Kunkel] #2783654
06/10/20 12:58 PM
06/10/20 12:58 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Yep, it sure will fit and it can be made to clear the heater box, steering box, etc. Pretty much everything has to be fabbed but I've done it and took a lot of pictures. You can notch the cross member to get a 727 to fit w/o butchering the transmission hump, too. I used a early-B 8 3/4 by moving the spring perches and it was perfect - even gave me a bit more room from the tire to the wheelwell lip.
Like I say, I've got a lot of pictures of my fabbed motor mounts, etc if you get into this.
Biggest bogie for me was managing the heat under the hood but eventually I got there.
Good luck, and enjoy the questions you will get: :"That ain't no Chivvy, what year Ford is that?"
