Re: Changing oil brand?
[Re: tboomer]
#2783635
06/10/20 12:27 PM
06/10/20 12:27 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
The Brad Penn has been the best oil I have ever used, that being said, they have switched it to Penn Grade. I have only had one oil change with the new Penn Grade as I am still trying to use up all the BP first. I have not seen any ill effects, but then again, I do not have anywhere near a season on that brand, just one oil change.......Before that I was using VR1 which I believe is still around today, and would be my backup....The consensus around here lately is everyone is going to Driven....Haven't tried it. I am told they have both full and semi synthetic. Everyone I know is running the semi....with good results. Why the BP had to change is beyond me....My engines are so clean with that stuff its amazing.
[Re: Dragula]
#2783650
06/10/20 12:55 PM
06/10/20 12:55 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
Nothing has changed, Penn Grade is the same as Brad Penn, which was the same as the old Kendall. Same oil it has been for years, no reason to change just because the name is different.
AS per Ted's question. For what you are doing I don't think I would worry too much about what oil is in it, but not sure Id change it that often either
[Re: Al_Alguire]
#2783695
06/10/20 01:52 PM
06/10/20 01:52 PM
Dragula
Some people I talked with have disagreed about the name changed and the oil stayed the same......... I am not saying either way, other than I have run a case of it with no issues, and it looked the same. Those folks switched to Driven. I have not tried that one or researched it. I looked at Amsoil & Redline, and I will stay with either BP or PG while I can get it.
[Re: bigdad]
#2783760
06/10/20 03:49 PM
06/10/20 03:49 PM
Al_Alguire
Las Vegas
I have probably been through at least 10 of Penn Grade thus far. Not one single issue. Just had the pan off the Stratus and pulled a couple rod caps and they still look like day 1. FWIW we run Driven oils in the heads up car but we need a 0w5 and that narrows the options for sure.
[Re: tboomer]
#2783764
06/10/20 04:00 PM
06/10/20 04:00 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I have always used Brad Penn oil in my 512 since it was built. The car hasn't been driven down the track for a few years but, I always change the oil and filter every year as I like to fire it up once in a while. I even keep the belts up to date in the hope that the Dr.s will let me drive it some day. As you can imagine,an oil change is pretty expensive. I did buy some Rotella 15-40 that I could change it with. Should I change the oil or what...Thanks guys! Ted Ted, sorry to hear that you can not drive this car. Funny how a simple oil change question can get into a debate.... So reading the post, with just starting and running it till good and hot with ZERO miles driven, Rotella will be fine. I think even if you drove (snuck) it down the block and goosed it a few times that the Rotella is fine. Just get it up to operating temps a few times a year for a half hour and that Rotella should be good for two years.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Bc65851]
#2784015
06/11/20 09:48 AM
06/11/20 09:48 AM
Posts: 11,998 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That statement really makes no sense. The API standards have changed many times over those 50 years. Today's oils bear little resemblance to oils from decades ago.
Master, again and still
[Re: 440Jim]
#2784140
06/11/20 01:57 PM
06/11/20 01:57 PM
Al_Alguire
Las Vegas
We sent an oil sample out from the dragster after dyno sessions using the penn grade. The facility was shut down from Covid and is now reopen and way behind but should have the results here soon. Not expecting it to be any different than before but we will have a concrete answer.
[Re: Al_Alguire]
#2784224
06/11/20 05:38 PM
06/11/20 05:38 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
that would be great to know , thanks Al .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Dave_J]
#2784237
06/11/20 05:58 PM
06/11/20 05:58 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I have always used Brad Penn oil in my 512 since it was built. The car hasn't been driven down the track for a few years but, I always change the oil and filter every year as I like to fire it up once in a while. I even keep the belts up to date in the hope that the Dr.s will let me drive it some day. As you can imagine,an oil change is pretty expensive. I did buy some Rotella 15-40 that I could change it with. Should I change the oil or what...Thanks guys! Ted Ted, sorry to hear that you can not drive this car. Funny how a simple oil change question can get into a debate.... So reading the post, with just starting and running it till good and hot with ZERO miles driven, Rotella will be fine. I think even if you drove (snuck) it down the block and goosed it a few times that the Rotella is fine. Just get it up to operating temps a few times a year for a half hour and that Rotella should be good for two years. ^^^^^ This.
