Re: Correct bolts on 4 spd bellhouse [Re: cudaman1969] #2789641
06/26/20 07:10 PM
06/26/20 07:10 PM
VA
dragon slayer Offline OP
VA
I am not, but I am claiming they used star lock washer on the trans to bell house (at least 70 up), I am also claiming the one 3/8" bolt is longer than the other 3. I also am claiming they where not the same bolts as the Auto transmission.
I did find a post with pictures from some fastener manual for mopars, but it has some conflict and errors too.
I have verified a 70 383 4spd with H bolts also, though I have not validated the length.
Re: Correct bolts on 4 spd bellhouse [Re: cudaman1969] #2789660
06/26/20 08:10 PM
06/26/20 08:10 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Originally Posted by cudaman1969
Originally Posted by 70440+6bbl
Here are the original bellhousing to block bolts from a ‘70 V code cuda (B18 SPD).
Are you claiming these are used on all manual trans bell housing?
No, this is the original hardware to a v code 4-speed cuda, but I'm sure bolt markings weren't always the same.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Correct bolts on 4 spd bellhouse [Re: 70440+6bbl] #2790891
06/30/20 07:29 AM
06/30/20 07:29 AM
VA
VA
Did you get anytime to measure bolt, and see that one head marking?
