welding helmet #2782354
06/07/20 11:32 AM
06/07/20 11:32 AM
new berlin wisconsin
Mr T2U Offline OP
Mr T2U  Offline OP
i bought, and just delivered, a panoramic view auto dark welding helmet from eastwood.
just opened the box and i haven't welded with it yet but it looks like it will be the best welding helmet i have ever used.
it's a little pricey at $150 ( SALE PRICE) $170. but i think it will be worth every $$.
it's sold out and ON BACK ORDER ALREADY, back in stock 8/17/2020
https://www.eastwood.com/panoramic-view-welding-helmet.html
perception is 90% of reality
Re: welding helmet [Re: Mr T2U] #2782362
06/07/20 11:53 AM
06/07/20 11:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Wow!
They have come a long way from the old helmets with the business card sized fixed glass in them.
Re: welding helmet [Re: Mr T2U] #2782363
06/07/20 11:58 AM
06/07/20 11:58 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Wow! I wish they'd had these when I was attempting to learn to weld 50 years ago.
welding helmets
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: welding helmet [Re: 3hundred] #2782369
06/07/20 12:15 PM
06/07/20 12:15 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
If you have older eyes like me and need more light transmission, when welding, try the Optrel Vega View 2.5 or the E684 unit. These are way better than the Miller Elite I was using. On lower amp settings, it was harder for me to see what I was doing and therefore could put too much heat in the weld. These Optrel units still protect your eyes but less of the weld view is blocked out. I'm using the E684 now as my original Vega unit is now too dark. Weldingsuppliesfromioc.com is a good place to check out for prices.
Carl Kessel
Re: welding helmet [Re: Mr T2U] #2782400
06/07/20 01:48 PM
06/07/20 01:48 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have had a number of auto helmets over the years. I also tried one of the big glass designs, however, when I'm welding, I still almost always just focused dead ahead on one spot. I think the big glass/lens helmets are overrated.
Re: welding helmet [Re: jcc] #2782402
06/07/20 01:59 PM
06/07/20 01:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A couple years ago I bought a new Miller to replace my old Jackson. I really like it, lots of adjustability and the head gear is the most comfortable I’ve worn. I also like the big view but at 59 I need cheaters so in essence they make it the standard small size.
Re: welding helmet [Re: jcc] #2782403
06/07/20 02:04 PM
06/07/20 02:04 PM
Mr T2U Offline OP
Mr T2U  Offline OP
the large viewing area helps in some situations in others it doesn't make much of a difference.
it makes a difference when you are welding in confined areas. like when you have to weld a section of a floor in a modern car next to the pinch weld clamp support while it's on the frame bench.
the biggest thing that interested me in this helmet was the "true color" part of the viewing area. i have never used a welding helmet with option. i was originally planning on buying the XL9300 helmet, https://www.eastwood.com/eastwood-xl-view-auto-darkening-welding-helmet-xl9300.html , then a saw this panoramic one i figure why not.
after trying it on. the viewing area is a little closer to your face than i am used to, so wearing a welding respirator might be a little difficult. i really like the larger viewing area especially with the side windows. it doesn't give you the tunnel vision claustrophobic feeling you get when using one with a smaller viewing area.***i also like putting something over the top of the helmet to keep the behind your head reflections to a minimum.
only time will tell.
Re: welding helmet [Re: Mr T2U] #2782411
06/07/20 02:45 PM
06/07/20 02:45 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Getting the view to be bright enough without blinding yourself is hard. But I found that with my large view auto helmet that I can wear my 3.2 reading glasses under it. But without any back lighting I still can not see the line to follow even at the 5/9 setting. So I have epoxied 4 small 5 volt DC LED 'Key Board' lights , 2 on each side aimed just a bit different, to the sides and run them off of 4 AA batteries with an on/off switch. The little back lights shine up the line so I do not drift too much. The whole package is only about 1/4 pound.
My old blower & filtered respirator mask will not fit under. But just hobby welding and using caution to grind off any Cadnuim or Zinc it is not too bad just wearing a PM2.5 mask under.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: welding helmet [Re: Dave_J] #2782465
06/07/20 05:29 PM
06/07/20 05:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: welding helmet [Re: justinp61] #2782475
06/07/20 05:49 PM
06/07/20 05:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And you need true color why ??
Re: welding helmet [Re: Stanton] #2782489
06/07/20 06:35 PM
06/07/20 06:35 PM
Mr T2U Offline OP
Mr T2U  Offline OP
it gives you a cleared vision on what you are welding instead of looking thru green.
Re: welding helmet [Re: Mr T2U] #2782502
06/07/20 07:24 PM
06/07/20 07:24 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
The true color lens is useful for a number of reasons. I bought one of the first lenses in number 11 many years ago that had the reflective gold tint and really liked it. It's easier to see soapstone marks, you can see a shadow better at the end of the joint you are working on and prep to end your weld, you can see contamination better, you can avoid mistakes and leaving birdschitt all over, and it's just plain better than the boring cobalt blue or green lenses.
At first I thought that panoramic view was kinda hokey, but I watched the video, and yup: I've been there mashing my helmet into a frame rail or something else in an out-of-postion weld. Usually, you can just put an 11 in a cutting goggle, but I like this idea better. Thanks for the "heads up" MrT2U. beer
What would be really nice, is if the side panels had individual adjustment and you could use them as lighter shade when needed so you can watch your work piece or whatever else is going on around you. Fab shop Folks will know what I mean.
Mo' Farts
Moderated by "tbagger".
Re: welding helmet UPDATE [Re: Mr T2U] #2800728
07/24/20 07:03 PM
07/24/20 07:03 PM
Mr T2U Offline OP
Mr T2U  Offline OP
i finally had a chance to do a significant amount of welding with this helmet today. i have used it several time while doing easy to do welds on easily accessible areas. but today was the first time i have used it for LONG periods of time in some really tight areas.
i got the lovely job of installing a USED 1/4 panel / rocker panel / rear body panel section on a 2018 jetta today. most people here aren't familiar with these cars so i will try to describe the problem area. what makes the job so bad is the 1/4 panel lip is folded over and glued the outer wheelhouse instead the usual 1/4 panel that has a flat flange where it's spot welded to the wheel house that most are used to seeing.
instead of destroying the 1/4 panel by trying to separate the 1/4 panel from the wheel house i cut the wheel house and left it attached to the 1/4 panel. after repairing the original wheel house outer wheelhouse i cut that so i could over lap both wheel houses and weld it there while the car was still on the frame bench. i was suposed to replace the complete wheel house due to damage but i sectioned it instead. it gets rather difficult doing this while the suspension is still on the car and the body is clamped to the frame rack.
i have to say the large panoramic makes welding in tight areas a walk in the park. the tru color part of the glass was really nice also, i have never used a welding helmet with this feature before.
i have to say it's the best welding helmet i have ever used.
my only complaint is the dimming glass sits much closer to your face than a regular auto dim helmet. the welding respirator will rest against the glass with the helmet in the down position. because of this it fogs up sometimes, never happened on my old helmet. maybe part of it was i really didn't ever have to lift the helmet to help see where i was at while staggering my welds to prevent overheating the weld area, the tru color part really helps when doing this over a regular dim helmet.. i really couldn't do this with my old helmet.
i have to give this helmet a 10 thumbs up satisfaction rating.
