Cam reluctor wheels. #2782010
06/06/20 09:03 AM
06/06/20 09:03 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Any difference between the 03-08 and 09 up cam reluctor wheels? If I'm not using VVT in a 6.4 build could I use an 08 and down wheel? Using an MS3 Pro Ultimate stand alone ecu.
Re: Cam reluctor wheels. [Re: fbs63] #2792641
07/04/20 01:47 PM
07/04/20 01:47 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
If you're talking about the cam sensor wheel i believe they are the same.
I had both in my hand and the patterns where the same.
Now i do not know if one will physically fit the other or be in the same place.
Remember the eagle uses the VVT and pushed the cam wheel out further.
Re: Cam reluctor wheels. [Re: MattW] #2793243
07/06/20 07:09 AM
07/06/20 07:09 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Thanks for the reply!
