AC Evap Change Out
#2779861
05/30/20 07:54 PM
05/30/20 07:54 PM
Posts: 1,534 Florida
CHRGR69
89 Dakota 3.9. Well, I got the dreaded Freon leak in the ac evaporator. Not looking forward to this. Any tips, strategies or instructions would be appreciated.
Grandma always said I had "hands of gold"!
Re: AC Evap Change Out
[Re: CHRGR69]
#2781936
06/05/20 10:26 PM
06/05/20 10:26 PM
Posts: 8,473 Candler,NC / Myrtle Beach, SC
JDMopar
Can't offer any advice on an 89, but on a 2004 Dakota....I had to drop the whole dash to get the heater/AC box out. I was doing the job the opposite way, with a bad heater core. I dang sure wasn't taking a chance on having to do it again, so I replaced my evap core while I was in there. If it has electrical door actuators, note what the dash control setting is when you take the box out, and take pictures of each actuator position before disassembly. That will save a lot of head scratching when you put it back together! Best of luck to you.
[Re: JDMopar]
#2781952
06/05/20 10:54 PM
06/05/20 10:54 PM
Posts: 954 garnett kansas
rhad
garnett kansas
on my 92 you need to remove the lower part of the right hand dash,normal wires/vacuum lines,about 6 or so nuts on the firewall side and the complete heater/ac box comes out on the passenger side
my ladder of success is missing some rungs
