Re: Front height adjustment
[Re: robertop]
#2781697
06/05/20 12:29 PM
06/05/20 12:29 PM
Posts: 17,861 albany ny
05dakota
albany ny
any change will requirement an alignment
5549 post on old board
[Re: 05dakota]
#2781715
06/05/20 12:49 PM
06/05/20 12:49 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
any change will requirement an alignment When you raise or lower the ride height with the torsion bars it changes the angle of the spindle which changes the caster, camber and toe in or toe out Get it aligned with the tires you want to run also
[Re: robertop]
#2781984
06/06/20 07:16 AM
06/06/20 07:16 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I've been told never adjust height with weight on tires and never use impact wrench.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: robertop]
#2781987
06/06/20 07:35 AM
06/06/20 07:35 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
taller tire shouldn't affect the aligment badly. Ride height is set in relation with ball joint and Torsion bar receptacle, so the LCA angle is what sets this, and height with floor given by a bigger tire wouldn´t affect on this.
diff stuff is that a bigger tire could require a diff aligment setup, but this doesn't take to a diff ride height given by the torsion bar bolt
NOW... crank up the T bar to the max? no per se, because on a worn T bar you crank up the bolt to the desired height no matter where the bolt is... but while higher the ride is, more to the limit are you on the geometry affecting shock aborber travel limit and camber/caster adjustment.
so the problem is more by the height itself than the bolt adjustment travel
