Re: Key won't start the car but a screwdriver will!
[Re: VITC_GTX]
#2781261
06/03/20 11:14 PM
06/03/20 11:14 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
The starter relay could be bad. The netural switch or wire could be bad. If stick, does it have a clutch in switch? The YELLOW wire from the Ignition switch to the starter relay could be bad. This could be in the bulkhead connector plug or at the ignition switch.
This is where a simple 12 volt test light is a good thing to have. It has a clamp on the long wire and a sharp probe tip to check connectors.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: stumpy]
#2781262
06/03/20 11:16 PM
06/03/20 11:16 PM
Posts: 4,915 Tri-Cities, Washington
VITC_GTX
If it's an automatic try starting it in neutral. Your neutral safety switch may not be activated. Your shift linkage could need adjustment. Good thought but it is a four speed.
[Re: Dave_J]
#2781263
06/03/20 11:20 PM
06/03/20 11:20 PM
VITC_GTX
The starter relay could be bad. The YELLOW wire from the Ignition switch to the starter relay could be bad. This could be in the bulkhead connector plug or at the ignition switch.
I beat the heck out of the relay but that didn't seem to help. I may try replacing it, they're not too expensive. I guess I could see a bad connection being the culprit but I'm surprised that bumping the solenoid would fix the problem every time.
[Re: VITC_GTX]
#2781265
06/03/20 11:32 PM
06/03/20 11:32 PM
Dave_J
Auburn WA
You are bypassing the relays inside contacts when you screwdriver the two lugs on the relay.
Some 4 speed cars has a switch on the clutch pedal that goes the the neutral switch of a starter relay too.
Tri-Cities is 150 miles too far for me to drop over to help, sorry.
If you had that test light I posted above I can tell you how to test each section, one at a time. Just throwing a starter relay on may fix it but there are other things to test too.
[Re: Dave_J]
#2781277
06/04/20 01:08 AM
06/04/20 01:08 AM
Dave_J
Auburn WA
The Auto and stick shift relays are different. RockRuto has repop ones.
[Re: Dave_J]
#2781280
06/04/20 01:51 AM
06/04/20 01:51 AM
VITC_GTX
If you had that test light I posted above I can tell you how to test each section, one at a time. Just throwing a starter relay on may fix it but there are other things to test too. I do have one of the old test lights and can test the system. The next time it happens I'll chase it down with the test light. Of course, it usually does it when I'm in a parking lot somewhere not when I'm home! Thanks for the good advice.
[Re: VITC_GTX]
#2781283
06/04/20 02:29 AM
06/04/20 02:29 AM
Dave_J
Auburn WA
With it happening 1 out of 50 starts, maybe just throw a new relay on. Then if it does it again you can chase it.
STANDARD MOTOR PRODUCTS SR106 $16.22 from RockAuto, $22.94 with shipping and Govenor's share.
[Re: Dave_J]
#2781284
06/04/20 02:40 AM
06/04/20 02:40 AM
VITC_GTX
STANDARD MOTOR PRODUCTS SR106 $16.22 from RockAuto, $22.94 with shipping and Govenor's share. Yep, that's the way to go. Thanks.
[Re: Dave_J]
#2781285
06/04/20 02:52 AM
06/04/20 02:52 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
That changed by the 70 where manuals used the same than autos too ( or it was 69? Can't recall ), needing to press the clutch pedal
