218 C.I. flat head six cylinder motor builders questions #2781135
06/03/20 05:04 PM
06/03/20 05:04 PM
Cab_Burge Offline OP
I have a customer who wants me to build his stock motor and use it for cruising in town and to out of town car shows. Stock specs. show it had either 95 or 97 HP stock, I would like to hop it up 25 to 50 HP more so it will cruise fast enough to keep up with traffic on the weekends, not to race it.. He likes the early to late 1950 cruising looks and performance work
He already has a 2 one barrel intake manifold and he wants to put twice pipes on it with Smitty glass pack type mufflers
I'm looking for suggestions on camshafts to use and piston brand to raise to compression ratio up to around 9.0 to 1 comp. ratio help
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Cab_Burge] #2781167
06/03/20 06:24 PM
06/03/20 06:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No go on pistons for that kind of compression ratio. If you look at the chamber design the bulk of the volume is over the valves and not the pistons. I went with an Edgy head that has a more modern chamber design and is smaller to get you the 9:1 compression ratio. Unfortunately, I also got one of the last sets they made and there are no more new ones. I did see on on Ebay, used, for twice what I paid for my new one. The company that made that head is working on a more stealthy one, same chamber design inside, but looks stock outside whereas mine are finned. So you just deck the block for quench and run a better head. They also do cams.
http://www.moparmontana.com
But these guys are really the 218 cam gurus
https://p15-d24.com/blogs/entry/109-the-all-mighty-cam-flathead-style/
Shot of my new cylinder head's chamber.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781168
06/03/20 06:26 PM
06/03/20 06:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
As for the intake you mentioned, which one? I am running a Thickstun and in the process of dual TBI injecting it. You can find that intake on Ebay semi-regular
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781187
06/03/20 07:28 PM
06/03/20 07:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd bet that for every flathead Mopar 6 that's been built, 1,000 Ford flathead V8s have been.
I would think a lot of the same tricks would apply, plus the Mopar probably doesn't have the heat issues of the Ford V8.
A racer buddy of mine does single-cylinder (Mustang scooter) motors and gets quite a bit more out of them, and there's almost zero HP parts for them.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: topside] #2781191
06/03/20 07:52 PM
06/03/20 07:52 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
218 CI is about what, 3.5 liter?
Leave it stock and put a Turbo on it. up
Leave it stock and put an Eaton Supercharger on it.
You can deck the head a bit and re-port the valve crossover pocket but not touch the quench side. Then deck the block 0.040".
I seen a Ford flathead that used golf ball dimpling in the valve and crossover port. The dimples are only 0.020" deep and done with a drill press. I think they got 10 HP and a better flame front.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Dave_J] #2781212
06/03/20 08:50 PM
06/03/20 08:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not sure what you mean by the valve crossover pocket but the stock combustion chamber is poorly designed for efficient combustion
Stock combustion chamber
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781256
06/03/20 11:03 PM
06/03/20 11:03 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I know thats for sure.
An OLD flat head racer told me the area over the valve in the head was the Valve Pocket and Valve crossover passage is the portion going over to the piston. The old flat head racer said to never grind out the area above the piston, only in the valve pocket and crossover. He also polished the whole chamber.
Knowing how hard it is to make compression with most of it trying to fill that valve pocket, thats why I think 10 PSI boost would help. 10 PSI should give 25 HP from this 218 CI
65 Formula S Cuda
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Dave_J] #2781306
06/04/20 08:50 AM
06/04/20 08:50 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You can mill the head a lot to reduce combustion chamber volume as well. But I figured I'd go with the updated head, not cheap either.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781326
06/04/20 10:12 AM
06/04/20 10:12 AM
moparx Offline
moparx  Offline
does this engine have an in block water "diverter" tube thing that can be rusted away or missing altogether, causing overheating problems ?
i seem to remember something about this in the dusty cobwebs of my inner cranium space.
or was that on the straight eight flat head ?
beer
Re: 218 C.I. flat head six cylinder motor builders questions [Re: moparx] #2781340
06/04/20 11:00 AM
06/04/20 11:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, they have the water distribution tube you are thinking of. You can get new ones, vintage powerwagons has them in stainless as well.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781383
06/04/20 01:14 PM
06/04/20 01:14 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I wish I had pictures of the guys flat head shop. He had about 25 different sets of flat heads on the wall. He was mostly into these 218 and other L6 flat heads. Some of his milled ones had to have furnace welded/brazed in the chambers and on the outside to raise the valve pocket up and relocate the sparkplug .
65 Formula S Cuda
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Cab_Burge] #2781403
06/04/20 02:25 PM
06/04/20 02:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My dad had me as a kid do a head gasket on our family 53 Ply with a six, all I remember is my dad smiled when he said he had the head milled .060"?, the head was really heavy, I painted it silver to look cool, and the local machine shop I believe did a valve job, in the car?
Re: 218 C.I. flat head six cylinder motor builders questions [Re: jcc] #2781427
06/04/20 04:19 PM
06/04/20 04:19 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
.060" is a mild shave. Zero deck the block and take about 0.85" off the head is a good number, assuming the head hasn't already been milled. Your best bet is to CC and set it up for the compression ratio you are looking for.
In the car valve jobs were the norm back in the day, heck guys used to do them on the weekend in their garage and drive to work Monday.
Yes, they are heavy, which is yet another reason I like my new head, it's aluminum.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Sniper] #2781485
06/04/20 07:21 PM
06/04/20 07:21 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I did a couple in chassis valve jobs on Continental motors when I worked at the Hyster dealership.
Buddy of mine has the boring bar from a shop my Dad worked at in the '50s. They bored cylinders with the block in the car.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: slantzilla] #2781492
06/04/20 07:31 PM
06/04/20 07:31 PM
Guitar Jones Offline
Well yeah those things needed to be rebuilt every 60,000 miles or so.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Guitar Jones] #2781497
06/04/20 07:41 PM
06/04/20 07:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Cast iron rings will do that
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Guitar Jones] #2781546
06/04/20 10:13 PM
06/04/20 10:13 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
A back cut on the valves work WONDERS on those.
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Cab_Burge] #2783564
06/10/20 09:48 AM
06/10/20 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I can't answer your question. But my old 51 PU sat for 25 years or so. All I did was change the oil, new cap/rotor/coil, plugs, plug wires and sent the carb to be rebuilt. Started up and ran great. I think to get any power you'd have to mill the heads. I'm guessing a "cam" guy to grind you up something. You can check https://p15-d24.com/forum/6-mopar-flathead-truck-forum/ that's where I got all my info. They also have a "parts" section.
Coming soon!!!!
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Mr.Yuck] #2783608
06/10/20 11:32 AM
06/10/20 11:32 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Keeping up with traffic could be better served with a transmission and axle ratio combo that keeps the engine in an RPM range it's happy with, that is to say lowish. Flatheads were notorious for breaking cranks if you spin them up over farm tractor RPM for extended periods.
I'd look at a T5 or similar and a 3.23 or 3.55 depending on tire size.
If I was building the engine for long term reliability I'd build it like any other, a light piston and H-beam rod combo with the crank properly machined and balanced. If the crank needed to be turned down to make an off the shelf rod work, I'd offset turn it for some extra displacement.
Add dual carbs and exhaust to suit.
Kevin
Re: 218 C.I. flat head six cylinder motor builders questions [Re: Twostick] #2783999
06/11/20 08:58 AM
06/11/20 08:58 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
The '53 218 in my '55 Plymouth wagon has no problem running at highway speeds. Although, with the deep rear gears and the 3-speed manual, it can be quite noisy if you try and run over 70. All I've really done to it was an HEI distributor and a new carb.
