Age of Slicks
#2780888
06/02/20 08:35 PM
06/02/20 08:35 PM
6_pack_runner
6_pack_runner
Anyone have any experience or first hand knowledge of how to determine whether it is safe to run slicks that have been sitting...for years.........my instinct says if they pass a visual inspection they should be fine, but that is just my common sense opinion. I now many will say just buy new and be on the safe side, but I plan on changing the rear housing and running a much narrower tire in the future and would rather not spend the $850+ for new tires and tubes just to run a half dozen events this year. I am buying new front tires and they have very slight weatherchecking on the sidewalls, but the slicks appear to be fine.
Re: Age of Slicks
[Re: ]
#2780916
06/02/20 10:09 PM
06/02/20 10:09 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Anyone have any experience or first hand knowledge of how to determine whether it is safe to run slicks that have been sitting...for years.........my instinct says if they pass a visual inspection they should be fine, but that is just my common sense opinion. I now many will say just buy new and be on the safe side, but I plan on changing the rear housing and running a much narrower tire in the future and would rather not spend the $850+ for new tires and tubes just to run a half dozen events this year. I am buying new front tires and they have very slight weatherchecking on the sidewalls, but the slicks appear to be fine. Send it. They may not be very consistent , but absent dry rot or cracking , I wouldn't be afraid to use them.
Re: Age of Slicks
[Re: topside]
#2780928
06/02/20 11:11 PM
06/02/20 11:11 PM
6_pack_runner
6_pack_runner
16-33-15 Hoosiers with tubes....been sitting for 10 years indoors in Texas....mounted on car, not sure if it was on jackstands......plan on keeping it 10.0 and slower for now
Re: Age of Slicks
[Re: ]
#2780945
06/03/20 02:14 AM
06/03/20 02:14 AM
Posts: 43,118 Bend,OR USA
Cab_Burge
You've have two choices, correct Try them or replace them I would try them, do a pretty long burn out to get to better rubber and be careful on that first run My S/P car had sat for over 6 yrs before I bought it and started racing it, it had a set of older Goodyear 16x33x15 tubeless on it that had one set of the cords on outside of the tires, both sides on both tires, broken at the wide part of the sidewalls It hooked and ran good, 9.23 at 143.MPH on the throttle stop for 1.7 seconds weighing right at 2750 Lbs. with me in it, for the rest of that year on those tires If there is any doubts in your mind about them being safe please replace them
Re: Age of Slicks
[Re: ]
#2781118
06/03/20 04:08 PM
06/03/20 04:08 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Well two things that stand out to me, define for us "years" and as already asked, under what conditions. Some of the other comments that have run slicks for over a decade, neglected to mention how often the tires were run. From my experience, which is true it seems for many things in life, worse thing is sitting/neglect vs regular use. Second, which is very much a current topic of the day, peace of mind and spending $850 on a new set you MAY NOT use next season, vs body damage to yours and maybe another's from a failed slick on track and the downtime and cost for repairs, aggravation, and mental anguish for making the wrong choice, etc. ie its all Risk vs reward, only you can decide. Me, a new set and not look back.
Re: Age of Slicks
[Re: sandmangtx]
#2781164
06/03/20 06:21 PM
06/03/20 06:21 PM
6_pack_runner
6_pack_runner
I think DVW can confirm this, on my GTX i have a set of hoosiers 14.5 x 32 x 15's that have been on the car for over 16 years, DVW has even put a plug patch in one. And the tires hook every time with very little burn out in my blown 68 GTX, best 60' 1.21 they hook good enough to rip the out put shaft right off the planetary. lol Sandmangtx...,..I believe you have my old car.....I sold and delivered it to Michigan back in 2005 or so....thought it was nw of detroit
Re: Age of Slicks
[Re: ]
#2781166
06/03/20 06:23 PM
06/03/20 06:23 PM
6_pack_runner
6_pack_runner
I think DVW can confirm this, on my GTX i have a set of hoosiers 14.5 x 32 x 15's that have been on the car for over 16 years, DVW has even put a plug patch in one. And the tires hook every time with very little burn out in my blown 68 GTX, best 60' 1.21 they hook good enough to rip the out put shaft right off the planetary. lol Sandmangtx...,..I believe you have my old car.....I sold and delivered it to Michigan back in 2005 or so....thought it was nw of detroit It Looks like the paint has been changed slightly
Re: Age of Slicks
[Re: 340Cuda]
#2784598
06/12/20 12:59 PM
06/12/20 12:59 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
What do you have to loose? If they don't work buy new ones. If they only work for a short time buy new ones. I don't think they will come flying apart at the first hit by any means. I see a lot of guys who run VERY old slicks. Just make the first burnout a good one and let er rip..
The ONE thing I would do befoe you run them is to check the rollout to make sure the tires are even or close in size before trying to run them.
Re: Age of Slicks
[Re: racerhog]
#2790086
06/27/20 08:22 PM
06/27/20 08:22 PM
6_pack_runner
6_pack_runner
I ran them a few weeks ago, no problems. Had them aired up to 10 lbs. cold on the first pass footbraking it, 1.42 60' spun hard and was all over the trac on the shift but overall felt fine. Next pass put them down to 8 lbs. slightly warm still, 4200 chip with transbrake 1.37 60' felt fine. I won't get a chance to get out much this year so they should serve their purpose.
I never liked that slight moving around on the top end in previous cars, how low do others run their bias slicks ? These are 16-33-15, have usually wun 14-32's in the past
Re: Age of Slicks
[Re: ]
#2790168
06/28/20 12:05 AM
06/28/20 12:05 AM
Cab_Burge
I ran 8.0 and 7.5 lbs. in my 6+ yr old Goodyear 16x33x15 with no issues at 147 MPH in the 1/4 mile. I bought a new set of M/T 14x32x15 stiffwalls at 7.0 lbs. also with no issues on the other end that I can remember. My rear rims are 15.0 inch wide also
Re: Age of Slicks
[Re: ]
#2790296
06/28/20 01:10 PM
06/28/20 01:10 PM
Posts: 19,342 north of coder
moparx
as to the moving around issue. what is your front end alignment specs ? was it aligned with the front end up 1" from static height ? is your rear square to the chassis ?
