Big block dist. cap..What post was #1 from Mopar ?? #341644
06/08/09 08:12 PM
06/08/09 08:12 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
On a 71 car with a big block what was the orig dist position (what way was the vac can pointing ) and what terminal does the number 1 wire go to ???? I know its 18436572 counter clockwise but what terminal did the factory put the number 1 wire on ? Im using a MP elec dist froma later year if that make a difference. I could not find this anyware in the FSM.
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: THESHAKERPROJECT] #341645
06/08/09 08:34 PM
06/08/09 08:34 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Usually the first or second terminal clockwise from the clip in the front.
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: THESHAKERPROJECT] #2780772
06/02/20 03:15 PM
06/02/20 03:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
To the lower right hand side of the front distributor cap hold down clip, around 4 O clock scope That is based on the oil pump drive gear installed like stock from Ma Mopar up work scope
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: Cab_Burge] #2780838
06/02/20 06:19 PM
06/02/20 06:19 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: bee1971] #2780840
06/02/20 06:23 PM
06/02/20 06:23 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Another
Siberian Huskies
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: bee1971] #2780873
06/02/20 07:44 PM
06/02/20 07:44 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I always just think, behind the rear clip, work you way forward.
Re: Big block dist. cap..What post was #1 from Mopar ?? [Re: 4406bbl] #2780905
06/02/20 09:36 PM
06/02/20 09:36 PM
VA
dragon slayer Offline
VA
You mean front clip. Big Block.
