Re: Clutch fan
[Re: Shatar4]
#2780851
06/02/20 06:53 PM
06/02/20 06:53 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
Uh, no. Something's up with that: thicker core, fan clutch shaft too long, maybe wrong shroud ? Describe the cooling system, what's been done or re-done, etc. Also, what you mean by "overheating": running hot, puking coolant, or what ? When did the problem start ?
Re: Clutch fan
[Re: Shatar4]
#2780876
06/02/20 08:00 PM
06/02/20 08:00 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I’ve personally seen to many fan clutches take flight into radiators to suggest ever using them on anything that revs rapidly. That being my opinion, if you choose to run one, what you’ve read is correct. Any shrouded fan will move more air with the blade tips out of the enclosure. I doubt that is the issue... but it is true. First thing I would check is if it’s working. A lot of them have adjustable thermostats. See if the fan is moving hot air. I’ve also noticed that many temp problems can be fixed with correct ignition curves.
