Belltech dakota spindles. #2780794
06/02/20 04:16 PM
06/02/20 04:16 PM
Amarillo, Tx
ramblebee Offline OP
Amarillo, Tx
Hello folks, been years since I’ve been on here. Some old timers may remember a write up I did on Dakota spindles to lower a d100.
I am in the process of this again but have a question for guys that stayed in the loop with this.
I remember hearing that Belltech changed the design of the 91-96 Dakota spindle and there was interference with the steering and brake rotor. I used the cheap chassis tech spindles 15 years ago with no problems. The Belltech spindles are actually cheaper than the Airbagit spindles. I’d rather go that route if possible. Anyone with recent firsthand experience with the Belltech spindles? Thank in advance!
Re: Belltech dakota spindles. [Re: ramblebee] #2781400
06/04/20 02:16 PM
06/04/20 02:16 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Probably can find some info over at https://www.dakota-durango.com/
Re: Belltech dakota spindles. [Re: ramblebee] #2826313
09/29/20 12:34 AM
09/29/20 12:34 AM
San Diego
JP8 Offline
JP8  Offline
San Diego
Did you ever find anything out about the spindles? I just bought a '76 D100 and have been reading https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2607359/1.html trying to lay out a plan.
Instagram : @5_points_racing
Re: Belltech dakota spindles. [Re: ramblebee] #2853953
12/01/20 06:59 PM
12/01/20 06:59 PM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
I did mine with Bell Tech spindles about 7 years ago. I don't recall any interference issues. When did the design change?
