Modern Air Conditioning, Anybody?
#2780536
06/01/20 10:39 PM
06/01/20 10:39 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi All, As some of you may know my stepfather is building a 1966 Dodge Charger with a big block 383, here is the build thread if anyone wants to follow it. https://board.moparts.org/ubbthread...s-1966-dodge-charger-restification.html. We have the engine mainly together and basically all we have left is the air conditioning, condenser, and radiator. I maybe missing a couple of things, anyway our plan is to put modern air conditioning in and NOT use the big and heavy RV2 to save a bit of weight and get cooler air. We are thinking of buying the Stage 2 Performance Kit from Original Air for $850.00, here is a picture and the link. We are looking for suggestions opinions and what have you about modern air conditioning prices and such, is there anything a bit cheaper than $850.00 with what we are looking for. Anybody? Any help, knowledge etc would be greatly appreciated. Thanks in advance everyone https://www.originalair.com/66-70-b...0-134a-engine-compartment-upgrade-kit-stage-2
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: Modern Air Conditioning, Anybody?
[Re: SportFuryS/23383]
#2780538
06/01/20 10:50 PM
06/01/20 10:50 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
Hi All, As some of you may know my stepfather is building a 1966 Dodge Charger with a big block 383, here is the build thread if anyone wants to follow it. https://board.moparts.org/ubbthread...s-1966-dodge-charger-restification.html. We have the engine mainly together and basically all we have left is the air conditioning, condenser, and radiator. I maybe missing a couple of things, anyway our plan is to put modern air conditioning in and NOT use the big and heavy RV2 to save a bit of weight and get cooler air. We are thinking of buying the Stage 2 Performance Kit from Original Air for $850.00, here is a picture and the link. We are looking for suggestions opinions and what have you about modern air conditioning prices and such, is there anything a bit cheaper than $850.00 with what we are looking for. Anybody? Any help, knowledge etc would be greatly appreciated. Thanks in advance everyone https://www.originalair.com/66-70-b...0-134a-engine-compartment-upgrade-kit-stage-2 I used about the same on my 68 Charger, rebuilt the factory ac/heater box, it will FREEZE you out, even when its 110deg outside.
[Re: Andrewh]
#2780588
06/02/20 08:54 AM
06/02/20 08:54 AM
Posts: 1,378 Az
69hemibeep
Az
Call the makers and ask if it will fit an A/C car. I was going to scrap the A/C in my 68 Valiant but I come to find out none of the existing holes in the firewall were usable and there is no kit to replace the push button vacuum controls so I kept the old system and went new under hood. The aftermarket is geared up for non A/C cars at least in the A body so call first.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#2780644
06/02/20 11:12 AM
06/02/20 11:12 AM
Posts: 30,247 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
An aftermarket AC system that will FREEZE YOU OUT ? I’ve got a bud that’s building a Willy’s that would love that option! Any aftermarket AC system we’ve ever seen is MORE than lacking
[Re: dIc dOc Deity !]
#2780648
06/02/20 11:20 AM
06/02/20 11:20 AM
Posts: 4,651 Wichita
GY3
Wichita
An aftermarket AC system that will FREEZE YOU OUT ? I’ve got a bud that’s building a Willy’s that would love that option! Any aftermarket AC system we’ve ever seen is MORE than lacking Then you haven't seen many aftermarket A/C systems.
#2780679
06/02/20 12:26 PM
06/02/20 12:26 PM
Andrewh
An aftermarket AC system that will FREEZE YOU OUT ? I’ve got a bud that’s building a Willy’s that would love that option! Any aftermarket AC system we’ve ever seen is MORE than lacking I think you missed where he used the original under dash part. Doing that I agree, the compressor doesn't make that much of a difference. The under dash part makes it freeze you out. not the under hood, assuming you have a big enough condenser.
[Re: Jim_Lusk]
#2780717
06/02/20 01:50 PM
06/02/20 01:50 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
The AC brackets are most likely Bouchillon. I'm planning on a complete aftermarket system for my '67 Barracuda convertible, but may piece some of it together. I used a Vintage Air GenV evaporator and matching in-dash electronic controller and pieced together an under hood set-up from Nostalgic A/C on my 5.9 Magnum based motor with factory serpentine belt drive. It works very well an fit nicely, as. Vintage Air does not offer an A-Body kit as of yet. I used the largest condenser that would fit in front of my radiator and had a local shop fit and crimp my A/C lines.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#2780782
06/02/20 03:37 PM
06/02/20 03:37 PM
Posts: 6,545 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
An aftermarket AC system that will FREEZE YOU OUT ? I’ve got a bud that’s building a Willy’s that would love that option! Any aftermarket AC system we’ve ever seen is MORE than lacking If your buddy has room for a VintageAir MK IV under the dash, it should keep him adequately refrigerated. I have one in my Polara wagon and it will make you reach for the low cool. Kevin
#2780813
06/02/20 05:15 PM
06/02/20 05:15 PM
CSK
Pattison Texas
Hay guyz ... hardly an automobile AC expert here AT ALL but I’ve ridden in enuff cars with AC and nothing I’ve ever come across would freeze you out..... other than my uncles turbo diesel Jetta My 2020 Charger works well - no complaints - but a freeze out job ? ... nOpE ! You have not rode in my 68 Charger LMAO, have you seen how large the evaporator is in a stock Charger, its HUGE , about 2.5 tons yes it will freeze you out
[Re: gtx6970]
#2780829
06/02/20 05:50 PM
06/02/20 05:50 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Does anyone know of any places that sells what I am looking for cheaper than $850? We would spend it if we have to but we would like to find something cheaper as $850 is a bit much.
[Re: Jim_Lusk]
#2780830
06/02/20 05:51 PM
06/02/20 05:51 PM
CSK
Pattison Texas
The AC brackets are most likely Bouchillon. I'm planning on a complete aftermarket system for my '67 Barracuda convertible, but may piece some of it together. Check with them ^^^^^^^
