fuel pump return regulator suggestions needed please
#2780734
06/02/20 02:15 PM
06/02/20 02:15 PM
Posts: 19,239 north of coder
moparx
i am installing an aeromotive 340lph pump into the tank of my 69 charger. the system will have a 1/2" return, but will start out carburated, with a possible TBI [sniper] in the future. as i would like to plumb this once, what return style regulator is recommended for this installation, and why ? TIA as always for the help !
Re: fuel pump return regulator suggestions needed please
[Re: moparx]
#2781247
06/03/20 10:42 PM
06/03/20 10:42 PM
Posts: 16,450 On the run…
BloFish
On the run…
Not really, Aeromotive is top notch. Just my .02
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2781333
06/04/20 10:28 AM
06/04/20 10:28 AM
moparx
i decided to use this one as a match to my 340lph pump. i have a 3/8" feed now, and i'm going to make a 1/2" return. if there is any corrosion or gunk in the feed line [new in 2000, but has sat with gas since 2007] i probably will increase the feed to 1/2". how far off the bottom of the tank should the return line be ? should it point any direction other than straight down ?
[Re: moparx]
#2781342
06/04/20 11:11 AM
06/04/20 11:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
i decided to use this one as a match to my 340lph pump. i have a 3/8" feed now, and i'm going to make a 1/2" return. if there is any corrosion or gunk in the feed line [new in 2000, but has sat with gas since 2007] i probably will increase the feed to 1/2". how far off the bottom of the tank should the return line be ? should it point any direction other than straight down ? Normally you would point the return away from your pick up.. doent really mater how far off the bottom
[Re: moparx]
#2781730
06/05/20 01:34 PM
06/05/20 01:34 PM
MR_P_BODY
The 1/2" up doesnt do a thing.. in a stock design we put the return right on the bottom.. that system is in every production Chrysler out there.. I worked in the Fuel and Exhaust lab for 35 years testing this stuff... the return just needs to be pointed away from the pick up and the air will rise in the tank
[Re: MR_P_BODY]
#2781764
06/05/20 02:23 PM
06/05/20 02:23 PM
moparx
thanks mr. P ! you are the guru of fuel, and i follow your advice ! another question [or two]. would it be advantageous to [somewhat] flatten the outlet into an oval to prevent stirring up any junk that may accumulate ? run the return [closer] to the rear of the tank ? also, what would be the minimum clearance around the in tank pump and pickup needed ? if it means anything, [and i didn't mention it previously] i'm using a reproduction stainless tank from van's auto.
