Holley Fuel Lines? #2780660
06/02/20 11:50 AM
06/02/20 11:50 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Years ago Fabulous Fabrications used to make these fuel lines, you had many choices too like 5/16" Vacuum sec. or double pump. He also made them in 3/8" as shown.
Is there a source for them now???
yes I know I can fab. myself but would rather buy a 5/16" for a Vacuum sec. Holley outright.
Thanks Ron
Re: Holley Fuel Lines? [Re: RJS] #2780675
06/02/20 12:19 PM
06/02/20 12:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think Summit sells various kits.
Re: Holley Fuel Lines? [Re: Mr.Yuck] #2780747
06/02/20 02:36 PM
06/02/20 02:36 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I didn't find anything that had the stockish look like these.
Ron
Re: Holley Fuel Lines? [Re: RJS] #2780985
06/03/20 09:50 AM
06/03/20 09:50 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I had that setup on my 440 powered truck. It looks great and works great. I personally don't like a lot of rubber fuel lines under the hood.
Re: Holley Fuel Lines? [Re: TooMany62s] #2780998
06/03/20 10:19 AM
06/03/20 10:19 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, too bad those are not longer made. I've ran the Fabulous Fabrication stuff on multiple cars and they worked really well.
'63 Dodge 330
11.19 @ 121 mph
Re: Holley Fuel Lines? [Re: GY3] #2781000
06/03/20 10:22 AM
06/03/20 10:22 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Yep The Right stuff makes something close but no cigar. They make it in 3/8" which isn't what I' after with a block that's designed for GM engines so I started to make my own and will a buddy complete what I need coming up from the filter.
Ron
