Need some help with the Bonneville Daytona #2778773
05/27/20 03:43 PM
05/27/20 03:43 PM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey, looking for a numerically lower than 2.76 8 3/4 gearset. I was told MOPAR made something in the 2.40 range at some point. Anybody have a line on a set? I have a 9" with 2.47s, but would sure like to keep it MOPAR.
I'm planning to be at Speed Week in August to break the Classic Production A engine Record.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778779
05/27/20 04:02 PM
05/27/20 04:02 PM
Canada
RobR Offline
RobR  Offline
Canada
I think 2.71's are as low as it goes.
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778780
05/27/20 04:06 PM
05/27/20 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why dont you try a Gear Vendor in it
wave
Re: Need some help with the Bonneville Daytona [Re: MR_P_BODY] #2778866
05/27/20 07:43 PM
05/27/20 07:43 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
$2800...I'm running out of $1000 bills for this project!
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778867
05/27/20 07:44 PM
05/27/20 07:44 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Dr Diff (Cass) says there were some in the 2.40 range way back.
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778905
05/27/20 09:30 PM
05/27/20 09:30 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Years ago I took apart a rear end and saved the gear ratio tag.
It was a 2:45 ratio so they were out there.
MJ
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778937
05/27/20 11:26 PM
05/27/20 11:26 PM
I saw a 2.4? gear ratio in a 1967 Dodge R/T convertible or GTX convertible, CRS now blush in a 7 1/4 inch rear end, not sure if it was original or not shruggy
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2778998
05/28/20 09:07 AM
05/28/20 09:07 AM
New York
polyspheric Offline
polyspheric  Offline
New York
... and shorten the driveshaft
Boffin Emeritus
Re: Need some help with the Bonneville Daytona [Re: polyspheric] #2779034
05/28/20 11:43 AM
05/28/20 11:43 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks guys. If it wasn't at least a solid 8 3/4 I wouldn't risk it at 950hp. Probably have to roll with the 9".
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2779043
05/28/20 12:08 PM
05/28/20 12:08 PM
Kirkland, Washington
Pacnorthcuda Offline
Curiosity question.......about what top speed are you shooting for???
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2779325
05/29/20 02:12 AM
05/29/20 02:12 AM
I have a 1940 Ford Tudor street rod I'm swapping the 8 inch Ford rear end out and putting in a 9 inch rear end out of a 1976/1979 Lincoln Versiale (SP)) that has 2.46 ratio maybe (by checking the ratio turning the pinion shaft until the ring gear makes one full revolution), I haven't taken them apart and counted the ring and pinion gear teeth to get the exact final ratio yet. I ended up with two third members that have the same ratio, one is a posi, and I don't think I want to use either one. I'm thinking a 3.4? something ratio with 28 inch tall tires with a AOD tranny. Both center sections have 28 spline axles
If you decided to do the Ford thing your welcome to the non posi third member for the shipping costs up
Re: Need some help with the Bonneville Daytona [Re: Pacnorthcuda] #2779899
05/30/20 10:43 PM
05/30/20 10:43 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Current record for Classic Production A-engine class (440-500"ish) is 237.7mph, so not to be greedy, I'll settle for 238mph. My 9" with 2.47 gears should put me there at 7200rpm with 28" tires, assuming minimal tire slippage. Faster is better, bur a two pass average on two consecutive days in the same mile of 237.8mph will do it.
Re: Need some help with the Bonneville Daytona [Re: Cab_Burge] #2779901
05/30/20 10:46 PM
05/30/20 10:46 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks Cab, you'll need to come down if I can make it to Speed Week!
Re: Need some help with the Bonneville Daytona [Re: Lifsgrt] #2780048
05/31/20 12:32 PM
05/31/20 12:32 PM
If things work out to the good maybe I'll be able to take you up on finally seeing racers run at Bonneville up luck
El Mirage dry lake racing was a lot different looking than the salt at Wendover up
Work on slicking that body up, reduce the wind friction up wrench grin
Good Luck up
Re: Need some help with the Bonneville Daytona [Re: MR_P_BODY] #2780049
05/31/20 12:35 PM
05/31/20 12:35 PM
wave
It takes power to run any overdrive, direct drive doesn't work
