Which coating for an intake manifold? #2779830
05/30/20 06:25 PM
05/30/20 06:25 PM
Boise
Moparteacher Offline OP
Boise
New (bare) TrickFlow intake going on the 383/432. I'm looking for recommendations to seal and protect, ease of cleaning, and something that's purdy.
Should I ceramic coat? Powder coat? Other?
And, what should I expect t o pay?
Pics please and recommendations.
Re: Which coating for an intake manifold? [Re: Moparteacher] #2779846
05/30/20 07:12 PM
05/30/20 07:12 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
..powder coated. Easy to clean, no oxidation.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Which coating for an intake manifold? [Re: Moparteacher] #2779847
05/30/20 07:14 PM
05/30/20 07:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As for me, I paint mine - and aluminum heads & water pump, if so equipped - the same color as the rest of the engine.
To my eye, it just looks cleaner, less cluttered & more professional.
If you like the aluminum look, a high-temp clear for aluminum should work.
Re: Which coating for an intake manifold? [Re: topside] #2779858
05/30/20 07:46 PM
05/30/20 07:46 PM
Guitar Jones Offline
I wanted to paint my magnum air gap but I don't think I can get to the underside of the manifold between the valley cover. So I think I'm just going to leave it alone and let it just get cruddy looking. It's own kind of patina if you will.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Which coating for an intake manifold? [Re: Guitar Jones] #2779871
05/30/20 08:19 PM
05/30/20 08:19 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I haven't tested it on an intake but my front end still looks like this (maybe some road dirt) and the calipers were done too. I used Eastwood's Exo Armor as a clear coating on all natural metal appearing parts. they claim it's good up to 2000° F....that's better than exhaust paint
Re: Which coating for an intake manifold? [Re: Moparteacher] #2779872
05/30/20 08:21 PM
05/30/20 08:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I powder coated my W-5 manifold.. was good for a few years but when doing jet changes it
stained where the bit of fuel ran down when un-doing the fuel line but it was nice in silver
wave
Re: Which coating for an intake manifold? [Re: Moparteacher] #2779990
05/31/20 10:04 AM
05/31/20 10:04 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Clear coat holds up very well on intake manifolds. But not the spray bomb stuff. You need the 2 part gun clear. Flattening agent will knock the level of gloss down if you want. And, as always, the durability is tied to the prep. Glass beading is about the best prep I have found.
Master, again and still
Re: Which coating for an intake manifold? [Re: Moparteacher] #2779999
05/31/20 10:39 AM
05/31/20 10:39 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've had very good results with VHT Engine Enamel clear in a spray bomb, but all the VHT paints work well in my experience.
Re: Which coating for an intake manifold? [Re: Moparteacher] #2780007
05/31/20 10:53 AM
05/31/20 10:53 AM
jersey
Spaceman Spiff Offline
jersey
Rust Prevention Magic.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Which coating for an intake manifold? [Re: Moparteacher] #2780032
05/31/20 12:03 PM
05/31/20 12:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I use high temp aluminum exhaust paint.....Fuel removes it, but its easy to touch up and prevents corrosion Looks like natural aluminum......
Re: Which coating for an intake manifold? [Re: Spaceman Spiff] #2780034
05/31/20 12:08 PM
05/31/20 12:08 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Had my intake & valve covers clear coated, didn't last long after a few jet changes the paint stained and won't come clean
Central Conn coatings, http://www.centralctcoatings.com/ did a great job with my headers at a great price.
So either I will strip them and run them bare or ceramic coat.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Which coating for an intake manifold? [Re: jughed] #2780057
05/31/20 12:52 PM
05/31/20 12:52 PM
I disagree after having one intake and a set of cast aluminum valve covers powder coated on one of my old race motors, that coating holds the heat into the parts horribly, not worth doing on any motor you want to make power, cooler air and fuel make more power work twocents
Re: Which coating for an intake manifold? [Re: Cab_Burge] #2780123
05/31/20 05:52 PM
05/31/20 05:52 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I like paint.
Re: Which coating for an intake manifold? [Re: Cab_Burge] #2780195
05/31/20 09:27 PM
05/31/20 09:27 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Maybe... but I'll be running e85, and have a fresh air scoop. I'm not worried about a few degrees of supposed heat retention. Whatever floats your boat.
Re: Which coating for an intake manifold? [Re: jughed] #2780203
05/31/20 09:54 PM
05/31/20 09:54 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I powdercoat mine using an eastwood kit.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Which coating for an intake manifold? [Re: jughed] #2780235
06/01/20 01:40 AM
06/01/20 01:40 AM
I'm not talking about a few degrees, I'm talking about having 110 F uncoated versus 190 + F coated after a run shock pukescope
The powder coating kept the heat in the intake manifold and valve covers a log time after a run also down That is how I found about it doing that whiney Money wasted on trying to make the engine better looking with the hood off at the races realcrazy
Re: Which coating for an intake manifold? [Re: jbc426] #2780746
06/02/20 02:36 PM
06/02/20 02:36 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
drool I like it
Re: Which coating for an intake manifold? [Re: Cab_Burge] #2780781
06/02/20 03:30 PM
06/02/20 03:30 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine has been powder coated for 5 or 6 years now with MANY e85 jet changes. Still looks almost brand new....smae with the valve covers.
I also had the cold air intake tube for the turbo polished and then powder coated clear. Still sparkling bright with VERY little upkeep.
