What colour is this ?
#2779945
05/31/20 06:41 AM
05/31/20 06:41 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Looking to repaint my Dart and like this colour, ideally would like a modern more available colour that is very close.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: What colour is this ?
[Re: deaks]
#2779958
05/31/20 08:25 AM
05/31/20 08:25 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Looks alot like my Q5 68' Depending on the camera and lighting it photographs green or blue
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2779970
05/31/20 09:15 AM
05/31/20 09:15 AM
deaks
robin hood country
Yours looks completely different. Be nice if I could get a modern match.
[Re: topside]
#2780002
05/31/20 10:41 AM
05/31/20 10:41 AM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Q5 turquoise metallic in 1969. 67-68 had two colors, LL1 dark turquoise and KK1 light turquoise.
JB Rhinehart, Realist
A-Body's RULE!
[Re: jlatessa]
#2780024
05/31/20 11:53 AM
05/31/20 11:53 AM
6bblFLASH
N.E. Ohio
That is one great paint job, almost looks enhanced....
Joe Yep. I would put money on it,its Q5. I have pictures of mine that it is very green too. Look up Q5 cars you will find all kinds of shades because of lighting angles digital cameras etc..
[Re: 6bblFLASH]
#2780030
05/31/20 11:59 AM
05/31/20 11:59 AM
Posts: 32,918 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
If you take that picture to a automotive paint dealer he could tell you what color is the closest. They can do digital paint matching.
[Re: Suregrip391]
#2780084
05/31/20 02:24 PM
05/31/20 02:24 PM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
MINI has a "Caribbean Aqua Metallic" but I'd imagine a modern paint for a modern car would be expensive compared to Q5 in a modern paint system all the 1969 Q5 cars look different because of different paint systems from different manufacturers painted by different shops with different techniques over the past 50 years - NONE of it is "the SAME"
[Re: deaks]
#2780101
05/31/20 04:33 PM
05/31/20 04:33 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Looking to repaint my Dart and like this colour, ideally would like a modern more available colour that is very close. That's 1969 Q5 PPG paint code 13534 Bright Turquoise Poly, sometimes referred to as "seafoam" depending on whether your looking at a Plymouth or Dodge paint chart, if mixed properly, the pearl and metallic additives cause the paint to "flop" in different lighting changing from blue to blueish greens as well the metallic/pearl "shimmering" effects , very striking colour... as mentioned find a good paint guy to mix it, problem with most mixers today is the computer generated formulas are condensed by the paint mfg's to offer one colour that's "close" in match, most if not all ALT's have been deleted from mix programs, if your mixer only has one mix formula available, ask to look at the paint keys for the shade range so that you can find the ALT mix formula your looking for.... I'd recommend a BC/CC for a true dynamic finish, but 69 Q5 looks great even when shot in straight enamel (OEM) FYI, keep in mind regardless of how successful your color match mix, it can/will be altered by value shade/primer base changes, coverage/technique by the painter, personally I'd shoot it in Dupont Chroma Premier CC/BC (now Axalta Chromax), I'd imagine the value shade is probably 4, but a lighter value shade up to 1/white would really set that color on fire Mike
[Re: DAYCLONA]
#2780146
05/31/20 07:01 PM
05/31/20 07:01 PM
Rhinodart
Rhinotruck
Rhinotruck
My 69 GTS 383 4-speed in 1982. The old instamatic camera is not up to snuff with the modern cameras...LOL The F5 door at least makes you see the differences in those colors...
A-Body's RULE!
[Re: Rhinodart]
#2780148
05/31/20 07:04 PM
05/31/20 07:04 PM
Rhinodart
Rhinotruck
Rhinotruck
And my 67 Dart GTS 383 4-speed convertible in LL1...
A-Body's RULE!
[Re: jlatessa]
#2780209
05/31/20 10:14 PM
05/31/20 10:14 PM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
Joe Agreed. Looking at the background, it appears this was taken under an overpass. I've never seen that area as bright as this picture shows it.
