RS27L9G Block found #2779835
05/30/20 06:52 PM
05/30/20 06:52 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Anyone looking for this? Cast 10-2-68
Re: RS27L Block found [Re: MO_PA] #2779859
05/30/20 07:52 PM
05/30/20 07:52 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What’s the vin no?
Re: RS27L Block found [Re: fastmark] #2779864
05/30/20 08:01 PM
05/30/20 08:01 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
RS27L9G150391
Re: RS27L Block found [Re: MO_PA] #2779868
05/30/20 08:07 PM
05/30/20 08:07 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I have the VIN listed from 2015 but no other info
if it is a recently "found" engine the GTX may be out there work but if the block has been around and asked about 5+ years ago - that could be where I got the VIN info shruggy
Re: RS27L Block found [Re: 6bblgt] #2779870
05/30/20 08:14 PM
05/30/20 08:14 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
My friend dropped it off today, the steel motor mount brackets look to be truck. This block had a hole in the side that has
been patched, it looks rough but it was used after the repair. I don't know if it was asked about before, my friend may know.
One side id .003 oversize and the other is .005 over.
Re: RS27L Block found [Re: 6bblgt] #2780410
06/01/20 04:58 PM
06/01/20 04:58 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
You said you have the VIN info, do you have any other clues to this car? The engine was in the Livingston MT. area then Billings MT .
