Gasoline AFR Converstion to Methanol #2779650
05/30/20 12:01 AM
05/30/20 12:01 AM
BigFish69 Offline OP
I have a AFX air/fuel gauge that reads from 9.0-16.0 AFR. The gauge is setup to read gasoline outputs but is also compatible with methanol. I put on an methanol carb and the gauge is reading 9.0-9.3 AFR at idle. Does anyone know the conversation OR the calculation to show the methanol AFR? I know the AFR at idle on methanol should be between 5-6 AFR. Any help would be greatly appreciated! Thanks
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779656
05/30/20 12:23 AM
05/30/20 12:23 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Easiest way is to just tune any fuel to the gasoline air fuel ratios you are used to, if the gauge is on a gasoline scale.
You could re-adjust gauge to alcohol stoich or tune in lambda but you'll probably end up calculating back to gasoline scale anyway.
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779661
05/30/20 01:36 AM
05/30/20 01:36 AM
Don't hurt your engine by trying to use AFR on E85, you need to read it in the Lamda scale for alcohol scope
Re: Gasoline AFR Converstion to Methanol [Re: Cab_Burge] #2779665
05/30/20 02:20 AM
05/30/20 02:20 AM
Cab
is there conversion to lamba
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779676
05/30/20 08:14 AM
05/30/20 08:14 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
If the gauge will read in lambda do so . Mine has a switch and different face that you swap.
More importantly learn how to read methanol plugs for timing and mixture. Far more valuable than any gauge and nothing like Gas
Re: Gasoline AFR Converstion to Methanol [Re: Wirenut] #2779680
05/30/20 08:54 AM
05/30/20 08:54 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I did the converting over on my racepac when I switched from pump fast to alcohol. I got the tune close by doing that but if I may suggest something buy and egt reader and weld a fitting in one or two tubes. I welded two in but have only used one and I have mine set were it runs very consistent. I finally added it to my racepac but if I remember right the other system I bought was around 300.00 to read one cylinder
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Gasoline AFR Converstion to Methanol [Re: Cab_Burge] #2779739
05/30/20 01:00 PM
05/30/20 01:00 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Doesn't matter as long as you know what you're trying to accomplish.
Stoich gasoline is 14.68 Stoich Meth is 6.45 Lambda 1.0
So if you're naturally aspirated and wanted to run for example .88 lambda WOT that would be gasoline 14.68 x .88 = 12.91 or meth 6.45 x .88 = 5.67
Yes you could convert gauge output to lambda or change it to meth stoich as a base point but doesn't matter if you don't have that option.
Re: Gasoline AFR Converstion to Methanol [Re: INTMD8] #2779768
05/30/20 02:00 PM
05/30/20 02:00 PM
The gage I have has no adjustments, it was reading around 9 at idle any idea what that would be on methanol ?
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779796
05/30/20 03:57 PM
05/30/20 03:57 PM
all AFX and ask them what to do with their gauge on E85 up scope
Do they have a tech info help page on their web site? scope
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779831
05/30/20 06:29 PM
05/30/20 06:29 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the math
14.68 x.62 = 9.10
6.45 x.62 = 3.99
so to answer your question, it's waaaaay fat.
here's a chart for the math challenged
Joe
Without Data, you’re just another guy with an opinion.
Re: Gasoline AFR Converstion to Methanol [Re: BigFish69] #2779930
05/31/20 01:17 AM
05/31/20 01:17 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Again, if your gauge is on gasoline scale, tune it to known gasoline air fuel ratios.
If gauge is set to 14.68 or gasoline stoich and it shows 9-1 at idle, as mentioned, pig rich. Not even sure how you could have accomplished this.
