Re: Wideband AFR sensor location
[Re: AndyF]
#2779439
05/29/20 12:33 PM
05/29/20 12:33 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Either side is fine, collector or in the head pipe shortly after the collector is fine. Make sure you mock it up first since the sensor is fairly long and you don't want to force the cable into a tight bend. While you have the car up on the rack I'd put a bung in both sides so you can swap the sensor from side to side in the future. This ^^^^^^^^^ and And make sure the sensor is angled, the wire end a little above the threaded end so moisture cant get or sit in the sensor & ruin it.
[Re: GregY]
#2779526
05/29/20 04:36 PM
05/29/20 04:36 PM
RapidRobert
where would you guys say to put it with ex manifolds?
[Re: GregY]
#2779663
05/30/20 01:50 AM
05/30/20 01:50 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
[Re: 360view]
#2779670
05/30/20 06:10 AM
05/30/20 06:10 AM
Posts: 4,457 Washington
madscientist
Washington
If it were my vehicle, after making the investment in a wide range AFR sensor, I would make the best use of the $ by installing eight bungs on all cylinders. After measuring and getting 8 cylinders balanced to your preferred tolerance, leave the AFR either in the “most average” cylinder, or in the leanest cylinder if you fear detonation on some of the future fuel you might have to use. Have you ever tried to tune with an O2 sensor in every primary tube? You will spend so much time for zero gain. It’s not worth it. And the O2 sensor is not the total answer. You can get lost very quickly with it, it will fib to you and not every sensor will read the same. It’s a tool and like any other tool of that sort it has its limitations. I’ve watched guys drive themselves nuts chasing an O2 number. You still need to look at the plugs, and then tune to those and the O2 numbers are what they are.
[Re: 360view]
#2780112
05/31/20 05:09 PM
05/31/20 05:09 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
If it were my vehicle, after making the investment in a wide range AFR sensor, I would make the best use of the $ by installing eight bungs on all cylinders. After measuring and getting 8 cylinders balanced to your preferred tolerance, leave the AFR either in the “most average” cylinder, or in the leanest cylinder if you fear detonation on some of the future fuel you might have to use. The leanest cylinder can be determined with a plug reading so only one bung is needed
