Re: test pic 68 turbo dart project
[Re: paul69cuda]
#2712457
11/03/19 03:25 PM
11/03/19 03:25 PM
Posts: 340 San Diego, CA
mopar_man619
San Diego, CA
heck yeah the hard work started to pay off !!
1967 Plymouth Valiant Gen III Hemi 11.42@119 youtube.com/moparman619
[Re: mopar_man619]
#2712496
11/03/19 05:52 PM
11/03/19 05:52 PM
Posts: 4,066 Mo.
racerx
Mo.
[Re: jughed]
#2779347
05/29/20 07:34 AM
05/29/20 07:34 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Well, how did she do? Sounds like a successful session.
68 Barracuda Formula S 340
[Re: Cab_Burge]
#2779453
05/29/20 12:56 PM
05/29/20 12:56 PM
Posts: 1,229 In The Hills
jughed
In The Hills
This.... Attaches directly to axles. No tire slippage. Can support up 6000 horsepower. Paul's car looks good on it, doesn't it?
[Re: paul69cuda]
#2780949
06/03/20 02:30 AM
06/03/20 02:30 AM
Posts: 43,116 Bend,OR USA
Cab_Burge
Those are excellent results Your motor really responded well to the changes You got me thinking about a Procharger now, DANG IT I'm under the impression that the EFI injectors should be good to 99.8 % duty cycle and still be safe, yes or no?
[Re: Cab_Burge]
#2780972
06/03/20 08:58 AM
06/03/20 08:58 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Those are excellent results Your motor really responded well to the changes You got me thinking about a Procharger now, DANG IT I'm under the impression that the EFI injectors should be good to 99.8 % duty cycle and still be safe, yes or no? Injectors get unpredictable above 85% duty cycle. Pintles start acting like a valve trane in float.
[Re: MoonshineMattK]
#2781296
06/04/20 07:11 AM
06/04/20 07:11 AM
Bad340fish
Tulsa OK
Wonder how long it takes to shim the attachment of the dyno to the axles? I think those dyne heads are on tracks and slide to and from the vehicle. The hub dynos sure have some advantages. No hole in the ground, no slippage, no tire worries.
[Re: Bad340fish]
#2781442
06/04/20 05:08 PM
06/04/20 05:08 PM
Posts: 287 NW Illinois
MoonshineMattK
NW Illinois
Wonder how long it takes to shim the attachment of the dyno to the axles? I think those dyne heads are on tracks and slide to and from the vehicle. The hub dynos sure have some advantages. No hole in the ground, no slippage, no tire worries. Looks like a slick deal. Just not sure how the car is aligned exactly square between them.
[Re: Bad340fish]
#2781444
06/04/20 05:10 PM
06/04/20 05:10 PM
MoonshineMattK
NW Illinois
Wonder how long it takes to shim the attachment of the dyno to the axles? I think those dyne heads are on tracks and slide to and from the vehicle. The hub dynos sure have some advantages. No hole in the ground, no slippage, no tire worries. My mind must be making it more difficult than it really is
