Re: Fuel bypass regulator... before or after [Re: Cab_Burge] #2779233
05/28/20 07:59 PM
05/28/20 07:59 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Not to hijack the thread, but I have a 4-port dual carb. regulator...How would I plumb in a return line with this regulator? I have ran it as is with 2 ports plugged.I want to switch to e85 and would like to have a return line. The internals have already been changed to run e85, but if i need a different regulator, so be it.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Fuel bypass regulator... before or after [Re: jughed] #2779245
05/28/20 08:25 PM
05/28/20 08:25 PM
Here
jcc Offline
jcc  Offline
Here
So for the regulator after the feed thinkers, the question remaining, put the regulator up by the engine with a low pressure long return, or back with the fuel cell and a short return?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Fuel bypass regulator... before or after [Re: jughed] #2779246
05/28/20 08:28 PM
05/28/20 08:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That looks like a deadhead regulator without a return port to me twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Fuel bypass regulator... before or after [Re: jcc] #2779253
05/28/20 08:40 PM
05/28/20 08:40 PM
AndyF Offline
AndyF  Offline
For EFI I'd put the regulator next to the fuel cell and just feed a high pressure line to the front. Not so sure I'd do that with a low pressure line though. Too many variables at play when you only have 5 or 6 psi. When you have 60 psi a long dead head stretch from the rear to the front doesn't seem to matter.
Re: Fuel bypass regulator... before or after [Re: jughed] #2779254
05/28/20 08:42 PM
05/28/20 08:42 PM
AndyF Offline
AndyF  Offline
Check with the mfg. If the black fitting is the inlet then it looks like you just have four outlets and no return line but maybe there is something else going on that I don't see.
Re: Fuel bypass regulator... before or after [Re: AndyF] #2779262
05/28/20 09:01 PM
05/28/20 09:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm thinking that the silver can is a pulse dampener so if its like 3/8 or bigger you might use that for
a return but check with the company
wave
