Re: Grounding to aluminum head?
[Re: Lee446]
#2779056
05/28/20 12:43 PM
05/28/20 12:43 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Try it and see The starter has the biggest current draw so providing the easiest path for the current makes a lot of sense to me I think iron conducts electricity better than aluminum
[Re: rickseeman]
#2779064
05/28/20 01:01 PM
05/28/20 01:01 PM
Cab_Burge
I see several errors on his information, gold is the best conductor, hence the gold plating of high end connectors for the high end devices, especially in the aircraft and space programs Basic electricity classes cover the different metals used in the power and entertainment industry, the power company converter to aluminum lines to save money even though they have to have to use a bigger line size compared to copper lines.
[Re: rickseeman]
#2779065
05/28/20 01:01 PM
05/28/20 01:01 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
We do it in the racecars. Both aluminum blocks but we have even seen excessive corrosion on the outside if they are not grounded.
[Re: Cab_Burge]
#2779067
05/28/20 01:05 PM
05/28/20 01:05 PM
Posts: 22,695 Bitopia
jcc
Bitopia
I see several errors on his information, gold is the best conductor, hence the gold plating of high end connectors for the high end devices, especially in the aircraft and space programs Basic electricity classes cover the different metals used in the power and entertainment industry, the power company converter to aluminum lines to save money even though they have to have to use a bigger line size compared to copper lines. I need to correct the above, Silver is best, but it tarnishes, where gold does not why gold is favored. For example, in FE racecars, the wiring is mainly pure silver.
[Re: jcc]
#2779227
05/28/20 07:40 PM
05/28/20 07:40 PM
Cab_Burge
Is this the series that replaced Formula one? If so I saw part of a race on T.V. of those cars and watching them accelerate away from a corner was not very exciding with out any exhaust note of the motor accelerating , no tire squealing noise or anything else
[Re: Cab_Burge]
#2779240
05/28/20 08:18 PM
05/28/20 08:18 PM
jcc
Bitopia
Is this the series that replaced Formula one? If so I saw part of a race on T.V. of those cars and watching them accelerate away from a corner was not very exciding with out any exhaust note of the motor accelerating , no tire squealing noise or anything else Welcome to the future. The kids won't know any better. I believe the hidden OP's original question, I can't see how any electrolysis he thinks he spotted has anything to do with grounding on the head, but that is only my guess.
[Re: Cab_Burge]
#2779242
05/28/20 08:23 PM
05/28/20 08:23 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
There is an Anode in a radiator cap for this.
https://www.ebay.com/itm/Anti-Electrolysis-Sacrificial-Anode-13lbs-Radiator-Cap-FREE-1-3-DAY-SHIPPING/202005618264?hash=item2f08791e58:g:uhoAAOSwPt9eoHQe:sc:USPSPriority!83617!US!-1
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Lee446]
#2779294
05/28/20 11:03 PM
05/28/20 11:03 PM
Dave_J
Auburn WA
Thanks for all of the replies, I think I will continue to ground to the head. Good to go. But I'd still think of putting an anode in some where. They also make drain plug replacements that screw in the radiator.
[Re: Lee446]
#2779417
05/29/20 11:27 AM
05/29/20 11:27 AM
Posts: 2,902 A shed in England
Tig
A shed in England
Grounding both heads will help with electrolysis when it's running, you have a basic battery exchanging ions through the coolant due to the dissimilar metals in the heads and block. Adding an easier "path" for the electrons flow will help reduce the electrolysis effect on the head studs,head gasket fire rings etc and technically,you get a better spark. I run an earth from the batteries in the trunk to the block, the starter motor turns the engine over a lot easier. Sure it adds weight but your ignition system will thank you. EDIT: Some coolants also have corrosion inhibitors which will help also but not all drag strips like you to run anti freeze / summer coolant
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: AndyF]
#2779540
05/29/20 05:20 PM
05/29/20 05:20 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
Grounding to the head is no problem, especially if you're also grounding to the starter or to the block next to the starter. What are you using for coolant? Distilled water might help if you are using tap water. Some sort of additive is also a good idea such as water wetter or something like that. i have read in a few places not to use distilled water. I'm not a chemist but it was said that distilled water has been stripped of all minerals and when you put it in you motor it will eat the metals to try and balance itself back out. it said use softened water whatever that is.
