Re: Pool solar cover options
[Re: Stanton]
#2778343
05/26/20 01:30 PM
05/26/20 01:30 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
I fabbed up a BLACK tarp and just lay it on top with four weights at the corners. When it's pool time just kick the weights off, tug it off by one corner and bunch it up out of the way. It isn't the prettiest setup but it is by far the lightest, easiest to handle and most effective:
Often it heats the top 6 inches of water so much that it's warmer than bath water. I have the suction set up to pull the hot water off the top,shoot it to the bottom and push the cold water up to get heated. Power of the sun with that black tarp is amazing.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2778393
05/26/20 03:48 PM
05/26/20 03:48 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
I have a 24" round as well (Northwest Indiana) and I have a 150k heater, but I still use the standard solar cover at times. There are above ground solar cover reels (one person) that can attach to the pool rail and when you rollup the cover, you then swing the opposite rail out of the way. That could be an option for you? I also have solar cover large J brackets that attach under the pool rail to store the cover when not in use. I did think about the roll up attachment as it seems pretty easy.
GY3 71 Demon 340
[Re: MI_Custumz]
#3016339
02/17/22 04:33 PM
02/17/22 04:33 PM
Posts: 2 CA
noemiasmont
CA
If you are using a heater, a solar blanket is a must-have item, as you can lose 50% or more of the heat gained overnight due to the heat transfer into the cold air. Also, about 75% of a swimming pool's heat loss is due to evaporation. A solar cover minimizes heat loss from evaporation by acting as a barrier between swimming pool water and the air. Another must-have for any pool is to have a sump pump. They are super important since they prevent all kinds of possible issues. I hired a group of professionals to build a pool in my backyard this summer, and they got the sump pump from sumppumpadvisor.com.
