Re: Broke a rusty weld stud for the wiper motor mount
[Re: hemienvy]
#2777889
05/25/20 12:47 AM
05/25/20 12:47 AM
Posts: 1,758 Phila
PhillyRag
Phila
Would it be a good idea to grind off the remaining stud and drill through the base, then tap the base to use a through-bolt ? Can't get to the base of the stud, it's inside the cowl, I don't know how the factory welded them........... I believe they were projection spot-welded on. Would work if the remaining base was still firmly attached on firewall, and it's large enough to accommodate the tap hole.
[Re: challengersteve]
#2778516
05/26/20 09:06 PM
05/26/20 09:06 PM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I just supported the back side with a socket and tapped the studs out with a hammer. The factory tack welds broke easily. Worth a shot !! Ihave these brackets that go in the doors and they have three studs each and two are broken on each bracket.
