Re: Spacer under a 4500
[Re: AndyF]
#2777770
05/24/20 06:59 PM
05/24/20 06:59 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
I don't know but my builder (Tony Bischoff - BES) told me I needed one. Motor should hit the dyno very soon. We settled on a 1 inch. I wanted phenolic for heat insulation, and I wanted o-rings - no gaskets. He gave me some direction and this is what I came up with. Tony said it should work.
[Re: dragon]
#2777875
05/24/20 11:13 PM
05/24/20 11:13 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
I tried a bunch on my 512. I am limited to 1" spacer under the carb......It ended up liking the big open spacer the best, and then I milled the clover leaf out of the intake for one big opening.....It really liked that.
[Re: 440Jim]
#2778094
05/25/20 03:20 PM
05/25/20 03:20 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
We actually make our own that have proven to be better than anything else we have run on the dyno. There are 4 of them at the dyno and they get used on almost every engine on the dyno and are always better from 5-25hp over the others..But here the thing. Many times on a dyno you can stack spacer to the ceiling and see more power, but at the track it flat don't work. Something that can work as a shear plate and spacer sized to the carbs throttle plate will usually net you some power on the dyno and track
