Six Pack Negative Cable Serrated Washer #2746104
02/24/20 02:38 PM
02/24/20 02:38 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have a 1970 Plymouth Superbird with a 440 Six Barrel engine.
I am looking for a correct and preferably original or NOS serrated washer for the negative battery cable end.
This manifold bolt also fastens the bracket for the throttle return spring.
The throttle return spring bracket has notches stamped into it for the special washer I'm looking for.
I have attached a picture of another engine with the correct washer in place.
If you can help send me a pm!
Thanks!
Re: Six Pack Negative Cable Serrated Washer [Re: moparjohn] #2746145
02/24/20 04:21 PM
02/24/20 04:21 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Is it a standard external star washer in a common size? Or is it a captured star washer that is part of the bolt head?
Terry
Re: Six Pack Negative Cable Serrated Washer [Re: 71vert340] #2746185
02/24/20 07:16 PM
02/24/20 07:16 PM
N.W. INDIANA
N.W. INDIANA
It is a standard external washer.
Thanks! John
Re: Six Pack Negative Cable Serrated Washer [Re: moparjohn] #2746271
02/24/20 11:02 PM
02/24/20 11:02 PM
GMP440 Offline
GMP440  Offline
It's just a lock washer. Widely used in the aircraft industry.
Re: Six Pack Negative Cable Serrated Washer [Re: GMP440] #2746274
02/24/20 11:06 PM
02/24/20 11:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I looked for that exact washer and never found anything that was I felt close enough.
Its an external tooth lock washer but the originals the serrated tooth was shaped different than anything I came up with
https://www.mcmaster.com/standard-washers/lock-washers/external-tooth-lock-washers-9/
Re: Six Pack Negative Cable Serrated Washer [Re: gtx6970] #2746765
02/26/20 04:17 PM
02/26/20 04:17 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
According to Frank Badalson, there is no washer here. This is from one of his tech articles I saved.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2015 BMW K1600 GTL
Re: Six Pack Negative Cable Serrated Washer [Re: RealWing] #2746889
02/26/20 09:39 PM
02/26/20 09:39 PM
N.W. INDIANA
N.W. INDIANA
Jim,
Thanks for the reply with the copy of the article and photos!
I guess I'm going to delete my wanted ad for a washer.
John
Re: Six Pack Negative Cable Serrated Washer [Re: RealWing] #2747806
02/29/20 05:09 PM
02/29/20 05:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The article says "always". I will respectfully disagree.
This one is on a 1968 model year 440 HP assembled 11-22-1967.
(note the original date coded spark plug wires too, this car has just over 8,600 miles on it)
Re: Six Pack Negative Cable Serrated Washer [Re: Alaskan_TA] #2747890
02/29/20 10:33 PM
02/29/20 10:33 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
its been apart.
Re: Six Pack Negative Cable Serrated Washer [Re: sixbbl 69] #2747940
03/01/20 07:27 AM
03/01/20 07:27 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted by sixbbl 69
its been apart.
I agree. Look at the lack of paint on the cable end. It appears it was under the return bracket at one time. Makes sense that the factory would make the connection as to not be able to corrupt the ability for grounding with paint. But back to the original topic and picture, it may just be an optical illusion that there is a washer there. That is probably the serrations on the brackets that appear to be a washer.
Re: Six Pack Negative Cable Serrated Washer [Re: fastmark] #2748422
03/02/20 09:38 PM
03/02/20 09:38 PM
N.W. INDIANA
N.W. INDIANA
I also thought that about the unpainted end on that cable.
I also agree that my original picture does not have a washer just the serrations stamped into the bracket.
I have removed the solid washer and touched up my bracket and it now looks like that picture.
Thanks for all the replies!
MJ
Re: Six Pack Negative Cable Serrated Washer [Re: RealWing] #2751309
03/12/20 03:26 PM
03/12/20 03:26 PM
Thomaston, CT
Frankie P Offline
Frankie P  Offline
Thomaston, CT
Funny my 4 Bbl return spring bracket has the imprint from a star washer. I just didn't know if the cable was under the or on top with washer under the bolt head.
70 Charger R/T 440 4spd Dana
Re: Six Pack Negative Cable Serrated Washer [Re: Alaskan_TA] #2751323
03/12/20 03:50 PM
03/12/20 03:50 PM
Thomaston, CT
Frankie P Offline
Frankie P  Offline
Thomaston, CT
Thank you for the info. I'm I will not have to take a manifold bolt out of a freshly painted engine.
Frank
Re: Six Pack Negative Cable Serrated Washer [Re: Frankie P] #2777331
05/23/20 11:33 AM
05/23/20 11:33 AM
South San Francisco, Ca
70sixpkRT Offline
70sixpkRT  Offline
What is the consensus on the negative battery cable about over or under the bracket on a A12?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Six Pack Negative Cable Serrated Washer [Re: 70sixpkRT] #2777499
05/23/20 09:12 PM
05/23/20 09:12 PM
Central,PA
62maxwgn Offline
62maxwgn  Offline
Central,PA
Under the bracket same as the others.
Break in oil.. Zinc?
by Chally426. 05/29/20 08:51 AM
Wideband AFR sensor location
by GregY. 05/29/20 07:02 AM
71 Road Runner Hemi Pilot Car
by tomsjack. 05/29/20 04:14 AM
Moparts Recent Posts
by VCODE. 05/29/20 09:11 AM
AMD Discontinuing More Products
by not_a_charger. 05/29/20 09:00 AM
7.75 X 14 Red Streak Bias
by Chally426. 05/29/20 08:57 AM
by gtx6970. 05/29/20 08:54 AM
