Drive Shaft #2777288
05/23/20 08:38 AM
05/23/20 08:38 AM
Maryland,USA
I
IRON MAN Offline OP
IRON MAN  Offline OP
I
Maryland,USA
I have a drive shaft but I do not know if it the correct one for a 1970 Roadrunner with an automatic 727 Transmission. Any help would be great since the Roadrunner is in pieces.
Re: Drive Shaft [Re: IRON MAN] #2777293
05/23/20 08:46 AM
05/23/20 08:46 AM
New York
sxbblcuda Offline
sxbblcuda  Offline
New York
What motor and rear?
Re: Drive Shaft [Re: IRON MAN] #2777300
05/23/20 08:58 AM
05/23/20 08:58 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The length is around 50 1/2" oc of the joint depending on your setup.
Re: Drive Shaft [Re: IRON MAN] #2777304
05/23/20 09:11 AM
05/23/20 09:11 AM
New York
sxbblcuda Offline
sxbblcuda  Offline
New York
1970 PART # 2996195 - 3.25 DIA., 53.64 INCHES., 727 TRANS., 8 3/4 REAR, 383 / 440
Re: Drive Shaft [Re: sxbblcuda] #2777367
05/23/20 01:06 PM
05/23/20 01:06 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
that # 2996195 fits a C - body . he needs a # 2996161 section 16-02-1 R code {plymouth B body } 1970 7290 U joints , 440 , 727 auto , 51.50 long , 3.25 diameter , . drive
Re: Drive Shaft [Re: 1969ronnie] #2777463
05/23/20 08:01 PM
05/23/20 08:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes it is 51.5 long for this Plymouth with 8.75.
66-70 Dodges and Plymouth are different length driveshafts for the same power train combo.
