Any problem checking piston-valve clearance this way?
#2776938
05/22/20 09:01 AM
05/22/20 09:01 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I didn't want to drive the hour to work and then an hour back to get my dial indicator, remove the valve springs and install the checking springs so I thought I'd just stack feeler gauges between the rocker and valve tip and see if the engine stills turns over with no binding at the critical points from 15* BTDC to 15* ATDC. And it does. I have .098 under the exhaust and .087 under the intake. I think I have enough clearance.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Any problem checking piston-valve clearance this way?
[Re: 340Cuda]
#2776940
05/22/20 09:07 AM
05/22/20 09:07 AM
Guitar Jones
Well I guess if you must know the exact number it would be very time consuming, but if you really only need to know that you have enough clearance then I think this worked.
[Re: gzig5]
#2776943
05/22/20 09:16 AM
05/22/20 09:16 AM
Guitar Jones
It should work, but are you sure you would be able to determine a slight interference? Say .005"? I'd be worried about something deflecting and allowing it to continue turning. I suppose I could continue to add a little at a time until it stops turning, but even if it were say .005 off I think I still have sufficient clearance. I've run my race engines much tighter than this without problems. The lifters are shimmed solid and the feeler gauges under the pedelstals are there to get zero lash.
[Re: Guitar Jones]
#2776993
05/22/20 11:55 AM
05/22/20 11:55 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have done it like that in the past but I used height checking springs and pulled all the spark plugs so that I had a better feel. You can bend a valve pretty easy if it hits.
Of course this does not work with hydraulic lifters.
[Re: markz528]
#2776998
05/22/20 12:11 PM
05/22/20 12:11 PM
Posts: 20,155 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I do every single one of my builds this way and will be doing another one today. I sneak up on my total clearance. If my clearance is running close to minimum I will clay them up and check them that way because doing it the feeler gauge way changes the valve timing a few degrees.
[Re: markz528]
#2777003
05/22/20 12:27 PM
05/22/20 12:27 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Of course this does not work with hydraulic lifters. Unless you bottom the lifters out first.
[Re: gregsdart]
#2777013
05/22/20 01:12 PM
05/22/20 01:12 PM
Guitar Jones
I shimmed a pair of stock rollers solid then shimmed under the pedestal to get zero lash. This also told me what the preload on the lifter would be. It' a tad light at .048 and .043. Hughes says .080 on these lifters so longer pushrods may be needed. And yes, I had all the plugs out so I could feel it better.
[Re: Guitar Jones]
#2777152
05/22/20 06:57 PM
05/22/20 06:57 PM
Guitar Jones
Well it runs, didnt bang any valves. Lifters are noisy though I figured they would be. Ordered some longer pushrods but it runs good and everything works as it should. I dkn't think I can continue to run the 87 octane crap in it anymore as it diesled a little on shut off. Might get some colder plugs for it. It has some Bosch E3's in it now of unknown heat range.
[Re: dvw]
#2777280
05/23/20 08:18 AM
05/23/20 08:18 AM
Guitar Jones
The pistons don't have valve reliefs, they are flat with a slight dish so not a problem on this engine but most valve reliefs are usually spec'd for what ever size valve they fit or for stock size valves.
[Re: Guitar Jones]
#2777313
05/23/20 09:45 AM
05/23/20 09:45 AM
Posts: 16,923 NC
440Jim
NC
I shimmed a pair of stock rollers solid then shimmed under the pedestal to get zero lash. This also told me what the preload on the lifter would be. It' a tad light at .048 and .043. Hughes says .080 on these lifters so longer pushrods may be needed. And yes, I had all the plugs out so I could feel it better. Wow, removed lifters and shimmed, removed rockers and shimmed, etc. I would have driven to work and back to get the dial indicator. The time spent taking the motor apart and putting it back to together correctly is worth considering. That said, you are close and should be OK, just don't float the valves with RPM.
[Re: 440Jim]
#2777381
05/23/20 02:29 PM
05/23/20 02:29 PM
Guitar Jones
I shimmed a pair of stock rollers solid then shimmed under the pedestal to get zero lash. This also told me what the preload on the lifter would be. It' a tad light at .048 and .043. Hughes says .080 on these lifters so longer pushrods may be needed. And yes, I had all the plugs out so I could feel it better. Wow, removed lifters and shimmed, removed rockers and shimmed, etc. I would have driven to work and back to get the dial indicator. The time spent taking the motor apart and putting it back to together correctly is worth considering. That said, you are close and should be OK, just don't float the valves with RPM. Lol, it was already apart except I had already bolted the heads back on thinking I was going to use a smaller cam, but the bigger cam showed up Friday and the smaller one did not and probably won't until Tuesday or Wednesday. I really needed to get this truck running so I figured I'd give it a try. Didn't really have anything better to do and the drive to work is excruciating even at 4 in the morning so...But it runs great, I can't complain, but probably will anyway.
[Re: Guitar Jones]
#2777601
05/24/20 07:34 AM
05/24/20 07:34 AM
Posts: 9,824 MI, usa
dvw
MI, usa
The pistons don't have valve reliefs, they are flat with a slight dish so not a problem on this engine but most valve reliefs are usually spec'd for what ever size valve they fit or for stock size valves. But not all. If its a custom piston the configuration could be tight in this area. In your case this method wouldn't worry me. But I wouldn't use this method ( or dial indicator either) as gospel. Especially if cam timing may be moved around. Doug
