Re: Who got in their winter upgrades?
[Re: Dragula]
#2776852
05/21/20 08:42 PM
05/21/20 08:42 PM
birdtracker
got my 540 all together, in and fired up. Waiting on a air fuel sensor and just got my new seat belts today. Updated all my safety gear, shoes, socks, and head sock . Looking to drive the beast down the road and see how acceleration responds!!! Birdtracker
[Re: Dragula]
#2776861
05/21/20 09:34 PM
05/21/20 09:34 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I got all my safety equipment re-certed/replaced just in time to sit and wait...All I need is a set of rear tires and set the suspension and I should be good. We'll wait on the tires until I see some loosening up. Got a new trailer too.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: hemi-itis]
#2776887
05/21/20 11:35 PM
05/21/20 11:35 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I did some work on the motor, set the timing and verified it with two different timing lights, new rear tires, change the front coil over shocks from a set of older steel Koni single adjustable to a set of new Afco external double adjustable aluminum. I also swap the front tires from the 28 inch tall Moroso to a set of shorter 25 inch tall to get the front end down some more and less roll out on the starting line for a better reaction time .
[Re: Dragula]
#2776895
05/22/20 12:30 AM
05/22/20 12:30 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
Switched to e85, got my carb back from Mark Sullens . Not sure if the wagon will pick up any et but fuel cost should be much less.
Ok
[Re: Hemi ragtop]
#2776917
05/22/20 07:14 AM
05/22/20 07:14 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I got my trans leak fixed, but I think the cam plug came out of the block because I had to get a tow due to a major oil leak. If you let the thing idle it doesn't leak a drop of oil, as soon as you drive it the bell housing is full of oil. I had fought the transmission leak so much last year that I was actually relieved that it was engine oil leaking.
I upset the hot rod gods somewhere in the fact that everything that is going wrong with my car lately requires me to pull the transmission lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2776933
05/22/20 08:45 AM
05/22/20 08:45 AM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
I had H P motors rewire my whole car after 30 plus years of electrical problems and he did a great job, no more worrying if its going to start before every round. He installed a new Quickcar switch panel with a push button starter ( can still use key if i want) which is really nice. I put in a new battery box as my old one was ugly and orange, and a new Jegs stainless steel radiator catch can, looks a lot nicer than the old plastic one i had. I also touched up the paint under the hood and replaced my expired belts. I wanted to replace my Weld Drag lights with new wheels I like the Holeshot R3's but at almost $500 a piece I just can't afford it right now. Car is in the trailer ready to go just waiting for the track to open. On my D150 I added a few chrome accents under the hood and replaced my old 90 2WD Ramcharger rims with new American Racing polished aluminum ones.
[Re: mopar dave]
#2776970
05/22/20 10:40 AM
05/22/20 10:40 AM
Bad340fish
Tulsa OK
That all looks really good, I need to up my radiator and fan game I just haven't done it yet. I don't overheat but on a hot summer day I have to keep my eye on it, especially on the highway.
I like the breather can setup, I need to do the same. I wondering if crank case pressure is what caused my cam plug leak. I had just shut it down from a hard romp on the highway when I got the leak a mile or two later.
[Re: Bad340fish]
#2776976
05/22/20 10:53 AM
05/22/20 10:53 AM
Posts: 16,487 On the run…
BloFish
On the run…
Finally getting around to a refresh, with new heads.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: mopar dave]
#2777023
05/22/20 01:39 PM
05/22/20 01:39 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Not really winter upgrades but lets call this first one second off season of 2020 upgrade. We actually got to run a few races at the beginning of the year and took home a few dollars already. But we had a little accident with the car and had to repaint the front end because of it. Also added a lower grille to the front end. My son did a killer job matching the paint with this much pearl that's not so easy to do https://youtu.be/cESMvIqDld0The one winter project we did get done was getting the new bullet into the dragster. Since I was unable to get a new block and got tired of looking I bought a used engine. Was "fresh" when I got it. But spent the winter fixing some issues with it and freshening it up again. Its a 600-13 based deal. Makes good power for what it is. Only 13..2-1 compression ratio and a cam in the low .800's lift and 288/292 duration. Certainly not on kill but for this lightweight engine on a stick it should work fine. Did make just under 1100hp and 960 ft/lbs of torque! https://youtu.be/GJhbTxYwGNs
[Re: Al_Alguire]
#2777038
05/22/20 02:02 PM
05/22/20 02:02 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Not really winter upgrades but lets call this first one second off season of 2020 upgrade. We actually got to run a few races at the beginning of the year and took home a few dollars already. But we had a little accident with the car and had to repaint the front end because of it. Also added a lower grille to the front end. My son did a killer job matching the paint with this much pearl that's not so easy to do https://youtu.be/cESMvIqDld0The one winter project we did get done was getting the new bullet into the dragster. Since I was unable to get a new block and got tired of looking I bought a used engine. Was "fresh" when I got it. But spent the winter fixing some issues with it and freshening it up again. Its a 600-13 based deal. Makes good power for what it is. Only 13..2-1 compression ratio and a cam in the low .800's lift and 288/292 duration. Certainly not on kill but for this lightweight engine on a stick it should work fine. Did make just under 1100hp and 960 ft/lbs of torque! https://youtu.be/GJhbTxYwGNs Is there a re eason you always go orange with your hotrods?
