70 cuda grill fastners #2776319
05/19/20 11:23 PM
05/19/20 11:23 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Where can I get the correct fastners to attach my top and lower grills on my 70 cuda
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 70 cuda grill fastners [Re: toplescuda] #2776320
05/19/20 11:24 PM
05/19/20 11:24 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Link would be helpful if someone has one
1971 charger
Re: 70 cuda grill fastners [Re: toplescuda] #2776666
05/21/20 08:56 AM
05/21/20 08:56 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Are you referring to the plastic washers and screws? Mike Ross told me that ones on eBay sold by Vans are the most accurate except for one clip. I bought a set but have not installed them but the look correct.
Re: 70 cuda grill fastners [Re: fastmark] #2776673
05/21/20 09:23 AM
05/21/20 09:23 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
This is the kit I used on my last build. The 71 style black plastic headlight bucket retainers will not work in a 70 grille, they are to tall. Also, the x3 black plastic round push pins for the lower valance insert also will not be used.
https://www.ebay.com/itm/Mopar-70-Cuda-Barracuda-Grille-Fastener-Kit-Screw-Grill-1970-NEW/401791467507?epid=5013273842&hash=item5d8ca33ff3:g:ibcAAOSw2QZdC9i1:sc:USPSFirstClass!44253!US!-1
Re: 70 cuda grill fastners [Re: HEMICUDA] #2777488
05/23/20 09:02 PM
05/23/20 09:02 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Thank you
1971 charger
Re: 70 cuda grill fastners [Re: HEMICUDA] #2779039
05/28/20 11:57 AM
05/28/20 11:57 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
[quote=HEMICUDA] Also, the x3 black plastic round push pins for the lower valance insert also will not be used.
Do these push pins not fit?
68 Charger
70 Cuda
Re: 70 cuda grill fastners [Re: FC7cuda] #2779326
05/29/20 02:20 AM
05/29/20 02:20 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Nope, not long enough. Also, I've only seen "U" clips and bolts holding them on with the two screws in the upper corners.
Re: 70 cuda grill fastners [Re: HEMICUDA] #2779340
05/29/20 07:00 AM
05/29/20 07:00 AM
WV
Little Detroit Offline
WV
oem correct fasteners littledeteroitrestorations@hotmail.com
Re: 70 cuda grill fastners [Re: Little Detroit] #2779352
05/29/20 08:21 AM
05/29/20 08:21 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
You have a picture?
Re: 70 cuda grill fastners [Re: HEMICUDA] #2779914
05/30/20 11:37 PM
05/30/20 11:37 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Looks to be original plugs.
68 Charger
70 Cuda
Re: 70 cuda grill fastners [Re: FC7cuda] #2779942
05/31/20 05:43 AM
05/31/20 05:43 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
We've disassembled 4 70 Cuda's here in the last year or so and I have worked on many others over the years and have never seen the plastic push pins on a 70, 71 yes. My 3,900 mile survivor also didn't have the push pins. shruggy Either way, the push pins being supplied in the kits are not correct and to short IMO.
Re: 70 cuda grill fastners [Re: HEMICUDA] #2781206
06/03/20 08:44 PM
06/03/20 08:44 PM
WV
WV
for grille fasteners # 54-0300 on our web site , no "push pin" that mike referred too.
