MSD Coil Readings
#2775888
05/18/20 06:09 PM
05/18/20 06:09 PM
Posts: 5,442 Indiana
YO7_A66
Indiana
I am testing my MSD 8222 (Vibration) coil and I found that it should read on the Primary side .7Ohms (- to + post) and on the Secondary side is should be 4.5kOhms (- to center post).
Mine shows .6-.7 Ohms on the Primary side but the Secondary shows 153.6-154.2kOhms. Do I have a messed up Secondary on this coil?
""The MSD Ignition Blaster High Vibrations Coil (Part# 8222) is not vehicle specific. The specifications are turns ratio: 100:1, primary resistance: 0.7 OHMs, secondary resistance: 4.5K OHMs, inductance: 8 mH, maximum voltage: 45,000 Volts""
Thanks Dave
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: MSD Coil Readings
[Re: YO7_A66]
#2775951
05/18/20 09:02 PM
05/18/20 09:02 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
34 times normal resistance? Yes, that is a problem.
[Re: CMcAllister]
#2775960
05/18/20 09:12 PM
05/18/20 09:12 PM
YO7_A66
Indiana
Thanks. I just wanted to make sure before I bought another.
[Re: YO7_A66]
#2775971
05/18/20 09:23 PM
05/18/20 09:23 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Check your meter and test method. I would expect the normal failure to be shorted turns so a lower reading. In my opinion it would not be a normal failure for resistance to increase.
[Re: markz528]
#2775983
05/18/20 09:59 PM
05/18/20 09:59 PM
YO7_A66
Indiana
I thought the number was way off so I measured the Primary side and the Secondary side at least four times each. I kept coming up with the same readings for both.
Thanks for the reply!!
[Re: YO7_A66]
#2775987
05/18/20 10:09 PM
05/18/20 10:09 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I just measured my 8222 coil and measure 5000 ohms. A very high reading like you got seems very odd. Could your reading be a meter problem?? calibration? Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: YO7_A66]
#2776071
05/19/20 09:14 AM
05/19/20 09:14 AM
Posts: 4,935 WI
Dcuda69
WI
Mine shows 6-7 Ohms on the Primary side but the Secondary shows 153.6-154.2kOhms. Do I have a messed up Secondary on this coil?
Thanks Dave Primary resistance....connect on + and - Secondary resistance connect on + and secondary tower https://www.autoblog.com/2016/08/01/how-to-test-a-spark-plug-ignition-coil/
[Re: Dcuda69]
#2776081
05/19/20 10:20 AM
05/19/20 10:20 AM
YO7_A66
Indiana
I just went out and rechecked to find the “-“ to “SECONDARY” and the “+” to “SECONDARY” have the same reading of 154kohms.
Thank you.
[Re: YO7_A66]
#2776188
05/19/20 04:46 PM
05/19/20 04:46 PM
YO7_A66
Indiana
I picked up a new #8222 on my way home from work and it measured .7ohms on the Primary and 6.15kohms for the Secondary.
Thanks everyone!
[Re: YO7_A66]
#2776216
05/19/20 05:56 PM
05/19/20 05:56 PM
markz528
Morrow, OH
I asked one of our electrical techs at work this morning to test this coil with his meter. His readings on the Primary side were .6-.7ohms, and the Secondary side were 154-155kohms. Both meters are older digital units and both meters started out with the L and were both zero’d out.
Thanks again! Interesting. Not what I would have expected.
[Re: YO7_A66]
#2776475
05/20/20 01:17 PM
05/20/20 01:17 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I did some hands on measurements of Magnum V8 stock coils and aftermarket replacements some years ago. Here’s info from an old post: .........
MSD Magnum Engine replacement coil
primary 1.2 ohms secondary 13,700 ohms
For Info, Here is what I measured on my 1995 model year stock Ram ignition coil this afternoon:
Number on side of coil: 56027966
Primary Resistance 0.99 ohms Primary Inductance 6.25 milliHenrys Secondary Resistance 12,250 ohms Secondary Inductance 41.9 Henrys
I put 6.3 volts of 60 cycle AC on the primary of the stock coil and got 453 volts AC on the secondary. The turns ratio of the stock coil might be about 453/6.3 = 72
Above measured with a seventeen year old BK Precision LCR Meter model number 875A and a Fluke 87.
The 1995 FS Manual says the coils are made either by Diamond or ToyoDenso.
For the Diamond the primary resistance is supposed to be between .97 and 1.18 ohms and the secondary 11,300 to 15,300 ohms.
For the Toyodenso the pri resis is supposed to be between 0.95 and 1.20 ohms and the secondary 11,300 to 13,300 ohms. ===================
Here's what the Accel catalog says about their Magnum Truck coil:
begin quote:
"DODGE "MAGNUM" TRUCK / JEEP 1997-90 SUPER COIL
Engineered with optimized low resistance, high turns ratio windings around an M36 high silicone magnetic steel C-core for higher energy and voltage outputs. Results in quicker starts, improved idle quality, crisper throttle response and more high RPM power. Compatible with late model MOPAR J-TEC computer controlled ignition system and MOPAR high performance ignition computers. Direct bolt-in, plug-in replacement. Can also work with an ACCEL, Mallory, Crane, Holley or MSD capacitive discharge ignition systems. Special high temperature epoxy resists shock and vibration, while increasing thermal conductivity. Brass coil wire contact increases energy transfer efficiency and resists corrosion better than aluminum. High dielectric strength "ACCEL Yellow" over molded housing.
SPECIFICATIONS Primary Resistance 1.0 Ohms Secondary Resistance 12.7 k Ohms Turns Ratio 76 : 1 Maximum Voltage 42,000 volts Peak Increase in Energy vs. OE 34% Peak Increase in Current vs. OE 17% Peak Increase in Arc Duration vs. OE 23% Peak Increase in Dwell vs. OE 36%
Dodge "Magnum" Truck / Jeep 1997-90 Super Coil . .140021"
end quote ==============
Here's what MSD says about the Blaster SS:
begin quote
Blaster SS Coil, PN 8207 The MSD line of Blaster Coils is known for great performance from the street to the circle tracks. Following in that performance line, the new Blaster SS Coil is ready to leave its mark. The Blaster SS is an E-core style coil, which is a very efficient design when it comes to producing high voltage and spark energy. The windings produce 300mA and can handle up to 48,000 volts when used with an MSD 6 Series Ignition Control. The windings are held secure in a Dupont® RyniteT injection molded shell and are then encased in an epoxy compound for protection against vibration and water. The primary terminals are located at opposite ends of the tall spark tower so there is no chance of arcing especially with the high dielectric characteristics of the Rynite housing. The Coil is compact enough to fit in tight areas and is supplied with vibrations mounts. Blaster SS Coil - PN 8207 CARB Approval Pending
BLASTER SS COIL SPECIFICATIONS Primary Resistance: .355 ohms Peak Current: 300mA Secondary Resistance: 6,200 ohms Spark Duration: 180uS Maximum Voltage: 48,000 volts Primary Inductance: 6milliHenrys Turns Ratio: 70:1 Tested with an MSD 6AL measured at plug gap. ==================
Bowling Ignition Circuit Simulator Stock Ram Ign Coil part number 56027966
Input Parameters Are the Following: Starting RPM = 500 Ending RPM = 5000 RPM Step = 250 Ignition Coil Primary Resistance (Ohms)= 1.0 Ignition Coil Primary Inductance (Millihenries) = 6.2 Dwell Angle (Crankshaft Degrees)= 30.0 Battery Voltage = 12.0 Ignition Coil Secondary Capacitance (Picofarads) = 100.0 Computation Results: Engine Charge Time Primary Current Secondary Voltage Energy RPM (millisec) (Amps) (Volts) (Joules) --------------------------------------------------------------- 500 10.0000 9.58 75714.7 0.287 750 6.6667 7.87 62219.0 0.194 1000 5.0000 6.61 52241.2 0.136 1250 4.0000 5.67 44845.0 0.101 1500 3.3333 4.96 39214.2 0.077 1750 2.8571 4.40 34808.1 0.061 2000 2.5000 3.96 31276.2 0.049 2250 2.2222 3.59 28386.1 0.040 2500 2.0000 3.29 25979.8 0.034 2750 1.8182 3.03 23946.3 0.029 3000 1.6667 2.81 22206.0 0.025 3250 1.5385 2.62 20700.1 0.021 3500 1.4286 2.45 19384.5 0.019 3750 1.3333 2.31 18225.5 0.017 4000 1.2500 2.18 17196.7 0.015 4250 1.1765 2.06 16277.5 0.013 4500 1.1111 1.95 15451.4 0.012 4750 1.0526 1.86 14704.8 0.011 5000 1.0000 1.77 14026.9 0.010 ********************************************
CraneCams LX91 Ign Coil
Input Parameters Are the Following: Starting RPM = 500 Ending RPM = 5000 RPM Step = 250 Ignition Coil Primary Resistance (Ohms)= 0.4 Ignition Coil Primary Inductance (Millihenries) = 5.3 Dwell Angle (Crankshaft Degrees)= 30.0 Battery Voltage = 12.0 Ignition Coil Secondary Capacitance (Picofarads) = 100.0 Computation Results: Engine Charge Time Primary Current Secondary Voltage Energy RPM (millisec) (Amps) (Volts) (Joules) --------------------------------------------------------------- 500 10.0000 15.64 113833.3 0.648 750 6.6667 11.73 85363.4 0.364 1000 5.0000 9.35 68047.3 0.232 1250 4.0000 7.76 56505.2 0.160 1500 3.3333 6.63 48286.3 0.117 1750 2.8571 5.79 42144.1 0.089 2000 2.5000 5.13 37383.0 0.070 2250 2.2222 4.61 33585.5 0.056 2500 2.0000 4.19 30486.8 0.046 2750 1.8182 3.83 27910.6 0.039 3000 1.6667 3.54 25735.2 0.033 3250 1.5385 3.28 23874.0 0.028 3500 1.4286 3.06 22263.6 0.025 3750 1.3333 2.86 20856.4 0.022 4000 1.2500 2.69 19616.5 0.019 4250 1.1765 2.54 18515.6 0.017 4500 1.1111 2.41 17531.6 0.015 4750 1.0526 2.29 16646.8 0.014 5000 1.0000 2.18 15847.1 0.013
